Stock hood hinge upgrade
What do you guys think about these?
I replaced the stock hood hinges with hydraulic ones from a '97 Taurus. They work great! Here is a shot of the upper mount. I used a couple of waterpump studs to align it with the bottom mount. There is a clip the holds the bolt in place that was supplied with the support. I just drilled a hole in the fender to secure the bottom. I was having some issues with hood alignment. When I installed these it fit almost perfectly the first time.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
Re: Stock hood hinge upgrade
Hmmm...I might try that.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
lets see a picture with the hood closed. looks like a cool idea.
Looks good there, how does it do at speed? I think the stock spring/hinge setup helps hold the back of the hood down when going down the highway or at least for the past 38 years I thought so.
I sure like the idea of not having to fight those springs though. |
Seems like an easy mod. I havn't priced shocks in a while, but they can't be to pricy. Theres nothing wrong with my hood springs besides the loud creeky squeak when you raise the hood. I think I'll try it one of these days. Thanks for sharing mobileortho.
Good job, how about some measurments for the lower attachment location.
Is that the best location, what would you change on the "next one". Thanks
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
those pic's look good,i really think your on to something with this upgrade. "TAKE A BIG BOW DUDE!" those hoods can really be a pain in the ass to line up.
Mr48chev: The truck is not on the road yet so I have not driven it at speed but I really don't expect any problems.
Solidaxel: The lower strut is 1.5" in front of the 3rd fender bolt from the front of the fender. At this point I can't really say that I'd cange anything.
