10-29-2008, 11:13 AM | #1 |
taking out headlight dimmer switch?
i did a search but couldnt find anything on replacing or how to get the dimmer switch out of the dash. i know i unscrewed the bolt holding it in from the front i got it loose but is there a notch or something on the back side that i need to do to get the knob to come out of the unit? i got new gauges and bezels and stuff to replace but cant get the wiper or dimmer switch out to change the stuff. thanks in advance
10-29-2008, 11:31 AM | #2 |
busted knuckles
Re: taking out headlight dimmer switch?
The dimmer switch or the light switch? The light switch to the left of the steering wheel has a button top. Push it and pull the knob out. Then unscrew the bezel and nut holding it in. The wiper knob is just a bezel and nut holding it in place.
10-29-2008, 11:36 AM | #3 |
perfect thank you ill try that when i get home
10-29-2008, 12:12 PM | #4 |
Between Trucks...
Pull the knob out first, then press the button on top, and pull the rest of the way. Might want to disconnect the battery ground first cause your lights will go on.
Beat it to fit, Paint it to match... |
10-29-2008, 01:00 PM | #5 |
It's a catastrophic success.
Here's what your feeling for.LOL
10-29-2008, 03:53 PM | #6 |
awesome thank you so much for that picture thall help a bunch
10-29-2008, 03:54 PM | #7 |
where in oklahom are you at?
10-29-2008, 04:03 PM | #8 |
busted knuckles
I almost broke mine before some one told me about that button. Pictures say it all.
10-29-2008, 04:07 PM | #9 |
its all about the +6 inches
it can be a total pain in the 12 bolt to remove, so be prepaired to try 5 or 6 times. Twist the knob, push, pull, and cuss.
That's the secret, you have to use the correct 4 letter words. |
10-29-2008, 04:33 PM | #10 |
Between Trucks...
If you pull it out, then press the button, it'll come right out the rest of the way.
10-29-2008, 06:26 PM | #11 | |
Old Skool Club
Oh, the wiper knob has a set screw that enables you to remove the knob. You have to do that before you can access the nut that holds the bezel and switch in place.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 10-29-2008 at 06:26 PM. |
10-29-2008, 06:33 PM | #12 |
72 chevys 4 life
yup the first time i was pulling the light switch thing out i thought i was about to break it i just pulled and pulled then went to this website and figured it out =) i love this place
I dont call it being young and dumb....I call it young and havin fun |
11-01-2008, 09:55 AM | #13 |
Yah I love those headlight switches. I have only had one pull out the first time while pushing the button. Most are a pita! If all else fails I pull hard enough on the knob and the knob pulls of the end of the shaft. I then finish pulling the switch and fight with it once it is out of the dash. Once the shaft finally comes out of the old switch I then tap it back in the knob and slide it in the new switch.
