Old 10-29-2008, 11:28 AM   #1
1970heavychevy
busted knuckles
1970heavychevy's Avatar
What are these holes for?
1970heavychevy is offline   Reply With Quote
Old 10-29-2008, 11:31 AM   #2
DomesticDisturbance
DomesticDisturbance's Avatar
Re: What are these holes for?
EGR valve
76 Chevy shortbed C-10, 350 w/turbo 350 trans(under construction)
cardomain page: http://www.cardomain.com/id/DmestcDisturbnce
DomesticDisturbance is offline   Reply With Quote
Old 10-29-2008, 11:35 AM   #3
1970heavychevy
busted knuckles
Would it run better if it had the EGR installed?
Old 10-29-2008, 11:37 AM   #4
Cyclone
Cyclone's Avatar
Runs better without, they are a manitenance item, use or make a plate. plate
Cyclone is offline   Reply With Quote
Old 10-29-2008, 11:40 AM   #5
1970heavychevy
busted knuckles
It had a plate but the gasket was old so I pulled it off and didn't know what it was for. Thanks
Old 10-29-2008, 11:51 AM   #6
justcuz
justcuz's Avatar
What year truck is that in?
justcuz is offline   Reply With Quote
Old 10-29-2008, 11:56 AM   #7
1970heavychevy
busted knuckles
1970 C10 but its a 70' 350 Impala motor.
Old 10-29-2008, 12:04 PM   #8
justcuz
justcuz's Avatar
OK, thats what I thought. Most trucks that early did not have an EGR valve. I see you have an HEI on it, so it is getting great spark. Do you have a curve kit in it? If it were mine I'd swap out the manifold for a non-EGR one. Look in the wrecking yard for truck manifolds, they are taller and have less junk on them. The intake out of a 70 Impala looks to be a lower profile manifold. Chevy makes several good factory intakes and a good cast iron one comes from a pickup. It is a little taller, giving you longer intake runners and a little better bottom end.
Old 10-29-2008, 12:11 PM   #9
1970heavychevy
busted knuckles
***Edited by Moderator****
You may only discusss sales or want to buys in the classifieds area of the board. To make a new post there you must be a subscribing member.
Old 10-29-2008, 12:46 PM   #10
1970heavychevy
busted knuckles
Sorry about that. It was more of a joke, needed the lol.
