Old 05-11-2002, 10:52 AM   #1
PitterPats72
Post TDC
OK, Got the remote starter to work. How do I know when it is at TDC.
A friend (on vac this wk) told me to put a piece of paper in the # 1 spark plug and when it "coughs" it out it is at TDC. But it seems that every time I hit the remote starter it coughs it out.
HELP, Thanks,
Pat
72 Chevy Custom 10 Deluxe (78K mi.)
95 Nissan Maxima (195K mi.)
73 VW Beetle (owned since 78; 96K miles)
84 Honda Nighthawk (2500 mi.)
I know too much foreign stuff; I've owned American too and they lasted
just as long.
73 VW Beetle (owned since 78; 96K miles) Engine rebuild by me done!
73 VW Super Beetle -New to me- Bought from original owner!
just as long.
PitterPats72 is offline   Reply With Quote
Old 05-11-2002, 11:10 AM   #2
Mongo
YES_____NO
Mongo's Avatar
Post
why dont you just remove all the spark plugs then trun the engine over by hand when the TDC mark on the blancer line up with the 0 on the timing tab your at TDC.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 05-11-2002, 11:30 AM   #3
shortbed70
shortbed70's Avatar
Post
Put your finger over the hole,#1 and when it pushes you finger off its close. Look at your balancer and bring the motor to tdc 0 on your timing tab and there you have TDC
1970 shortbed(project)
350/350 dropped 4/6 21/2" flowmasters. Dropping bigblock idea and building a stout smallblock...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-11-2002, 11:36 AM   #4
PitterPats72
Post
just as long.
just as long.
Old 05-11-2002, 12:19 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Mongo, if you don't make sure the valves are closed (my checking for aif being pushed out) you may end up with it being 180 degrees out.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-11-2002, 03:59 PM   #6
PitterPats72
Post
Thanks got it to TDC and the distributer was pointing to #1.
just as long.
just as long.
