10-29-2008, 02:39 PM | #1 |
Amateur Rust Fighter
Power steering box install question
Ready to install the power steering box on my '72 and have a question. The box I'm using is a good used unit and came with the four bolts that attach it to the frame. However, one is slightly longer (by 1/4") and has a 1" spacer on it. What's the function of the spacer and where does it go? Can I just get rid of it and bolt the thing right to the frame directly? I bought it already off the truck so I didn't see how it was originally attached and I have, of course, forgotten which hole I took the odd bolt out of when I stripped it for painting.
If anyone has a quick answer I'd REALLY appreciate it. The weather is cooperating and I want to get it bolted up ASAP. Thanks, Brent
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
10-29-2008, 03:45 PM | #2 |
Re: Power steering box install question
If memory serves me right, that spacer goes between one of the holes of the gear box & the frame that has an indentation in it. It takes up the gap of the indentation on the frame. That is also where that long bolt goes thru.
1997 GMC Sierra Ext 1965 Mustang |
10-29-2008, 03:56 PM | #3 |
The spacer goes under the head of the bolt. That bolt is tucked up near the x-member---bottom front I think. Be sure to torque them down-- iirc 60 lbs, dab of locktite won't hurt either
10-29-2008, 04:04 PM | #4 |
Thanks for the reply. Sadly, just found out that I got screwed when I bought this box a year ago. It apparently is for a 4x4 and won't work on my 2WD. I was trying to figure out why the Pitman arm didn't have the stud on the end and when I started looking around I discovered the Pitman arm (and therefore the rest of the setup) is for a 4x4.
Hopefully I can sell it and recoup some of my money. Just ordered a new setup from CPP because I can't waste any more time getting this thing back together. Now I'm another week behind and another week closer to winter. This is what I've got....
10-29-2008, 04:35 PM | #5 |
Looks purty though
10-29-2008, 05:00 PM | #6 |
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) Last edited by brossow; 10-29-2008 at 05:00 PM. |
10-30-2008, 09:28 PM | #7 |
the way i understand it, the only difference is the pitman arm. Maybe someone else can confirm or rebutt this.
10-31-2008, 05:54 AM | #8 |
A 2wd box has a different sector shaft where the pitman arm lines up and goes side to side where as a 4wd box goes front to back.
