10-29-2008, 02:43 PM | #1 |
Engine n00b
Grrrrrrr... cant trust anyone
I took the truck to a shop 2 weeks ago to do an overall "how is it" and to install my distributor and new plugs.
When I got it back, it had an odd "studder" when in DRIVE and brake fully depressed where it feels like the truck is trying to jump out from under the brake. Seems like it has a cam or some "lumpiness" in the idle. It also had an odd hissing sound, and was idling too high, so I took it back. They lowered the idle. it still hisses. It still stumbles. Done with that shop for now and will look for another shortly that is closer that I can trust. Oh yea, and they didn't charge me for the re-visit, which was mighty nice of them, considering that I got the truck back with a chunk of metal in the tire. They claim it came in like that, and 2 hours after I parked it, she was flat. Either way, I am NOT having a good truck day. So I ask you guys..: Hissing - really can only be the vacuum or the PVC hoses. Maybe I should replace all them and the PVC breathers? Any other things to look at there? Stumbling - I really have NO idea here. My compression per cylinder was tested and good. They tuned timing after the distributor swap. What can I check/try here? Thanks in advance, I need a quick win so the truck makes me smile (before I go to the tire shop and they tell me its not a patchable hole - I spent $600 on tires 4 mos ago!) |
10-29-2008, 02:59 PM | #2 |
Neighborhood Pickle Slinger
Re: Grrrrrrr... cant trust anyone
I say go try and get a second opinion. If it didnīt hiss before you brought it there and it didnīt stumble, it sounds to me like they did something wrong.
I think some garages will listen to it and can tell you what is wrong. Go back to the garage where you had it and tell them what is wrong and have them fix it. Where is the hissing coming from? More towards the engine or more from the Tranny? The stumbling sounds like the advance isnīt working right. Do you have points or HEI? Make sure the vacuum is hooked up to the distributor. It could be alot of other things too but these are some of the common problems.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 Last edited by blukangoo; 10-29-2008 at 03:00 PM. Reason: Corrected some spelling |
10-29-2008, 03:01 PM | #3 |
sounds like they didn't hook up the vacuum advance on the distributor. try retracing all the vacuum hoses to make sure they are all hooked up where they are supposed to be.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 360 w/46RE 392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB 350 w/ 700R4 3.73 posi PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 10-29-2008 at 03:02 PM. |
10-29-2008, 03:01 PM | #4 |
did you change from a points distributor to an hei dizzy? if so did you explain to them about eliminating the resistor circuit?
10-29-2008, 03:09 PM | #5 |
Sounds like a timing issue (retarded too much) and a vacuum leak what type of carb, dist, intake? Holleys and Edels have a big vac port and the rubber plugs like to split and crack and leak!
10-29-2008, 03:24 PM | #6 |
Hissing might be a bad (or leaking) carb seal. Does it change in pitch/volume when the accelerator is hit?
10-29-2008, 03:56 PM | #7 |
Engine n00b
10-29-2008, 03:57 PM | #8 | |
Engine n00b
And I was going from HEI to HEI, BTW - the existing one was an older HEI, I put in a skip white ebay one. |
10-29-2008, 04:06 PM | #9 |
Next project: 1970 K10
Never mind, I need to read more before I post!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 10-29-2008 at 04:07 PM. |
10-29-2008, 04:24 PM | #10 |
I say get a friend that knows more than you do that you can learn from.....
10-29-2008, 04:46 PM | #11 | |
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
10-29-2008, 05:06 PM | #12 | |
Between Trucks...
Beat it to fit, Paint it to match... |
10-29-2008, 06:18 PM | #14 |
If you were in Houston or coming through here I would say bring it by and we will figure it out. If you come to Houston with it soon let me know. Or find a board member in Austin that can help you out.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-29-2008, 06:51 PM | #15 |
Engine n00b
10-29-2008, 06:53 PM | #16 | |
Engine n00b
Guess its time to hit the books as well. The book will guide me nicely for the vacuum and PCV stuff... still need some hints on what to check/look at for the stumbles tho |
10-29-2008, 06:56 PM | #17 |
It sounds like it could be a problem in the plug wires.Check the connections and if thhey are in proper position.What are thier condition?Check the plugs.
10-29-2008, 06:58 PM | #18 |
Engine n00b
plugs are new, gapped to .035, and wires are also new, but I did not confirm plugged in right or tightly at all connections. Will re-review this and make sure they didnt do sh**y work.
10-29-2008, 10:04 PM | #19 |
I'm not to far from ya, I'm up in Round Rock, my driveway is always open to help out fellow members. I'm sure we can get to the root of you're problems pretty easy.
Let me know .. Scott |
10-29-2008, 10:16 PM | #20 | |
Engine n00b
need anything from in town? |
10-29-2008, 10:29 PM | #21 |
Parts and more parts
Sounds like you have a bad truck. I'll give you $5.00 for it and then you won't have any problems with it.
Now seriously---did they pull the carb? If not, then the symptoms that you have described is a good hint that you have a vacuum leak ( a large one). The timing should be checked again, because I agree it may be set too low. I would also check the spark plug wires to see if they are in the right order. There is an excellent chance that while they were messing with the dizzy, they pulled the vacuum line off of the tranny's modulator or cracked the hose at the end of the tubing. That will cause a bad idle, a bad tranny shift characteristic and stumbling at a stop, while in gear. If it was my truck, I would want the idle at 700 to 800 RPM (In Drive gear---automatic) I personally would want my timing advanced to keep the performance and the gas mileage up on the engine. I set mine at 12 degrees in the past and it always worked for me. One final check---look at the inside of the dizzy cap for any damaged contacts or a cracked rotor on the E-bay find. |
10-29-2008, 10:38 PM | #22 |
I know its not my place but heres an Idea |
10-29-2008, 11:01 PM | #23 |
isnt the gap for plugs with hei suppose to be a .45 thats what i was told and the gap for points are at .35. let me know if i am wrong .my truck runs very good and responds well.
10-30-2008, 02:06 AM | #24 |
well i do most of the work my self and what cant do or need help all my friends will help me with any work
10-30-2008, 06:53 AM | #25 |
I`m still thinking they may have gotten a plug fouled while working in it.It just sounds like a dead cylinder with the way you describe it running.That`s "if" the vacuum problem isn`t connected to the rough running problem.
