Old 10-29-2008, 04:14 PM   #1
wedgemon
wedgemon's Avatar
One More Time - Headlight switch removal.
How DO you release the headlight shaft for removal from the front?
Pics would be a huge help.
Yes, I did a search. And, I tried it with a flashlight... No luck.
BTW - This help is needed for both a 73 K5 & 79 K10.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 10-29-2008, 04:21 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: One More Time - Headlight switch removal.
if memory serves correct there is a spring type button on the top close to the dashboard.. you push this in and yank out the pull knob and then you can acccess the screw nut from underneath to allow the switch to fall out under the dash where you unclip the harness
im thinking about it and im not sure if you have to unscrew the dash bezel to access the screwnut to drop the switch,,,
i dont believe i have a switch here to take pics of
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-29-2008, 04:43 PM   #3
78 Chevyrado
You pull the handle out to full on position, and then you press the release button (white arrow) then the handle will come all the way out. To replace the handle just stick it in, no need to press the button again.
78 Chevyrado is offline   Reply With Quote
Old 10-29-2008, 05:23 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Correction.... You DO NEED TO PUSH IN THE BUTTON TO REINSTALL THE SHAFT. Otherwise you'll shove the internal plunger all the way to the bottom (back) of the switch making it a real P*I*T*A to get back out unless you have a small crochet' hook to reach into and pull it back up.
Been there done that a couple of times. No fun at night out in the middle of B.F.E.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-29-2008, 06:52 PM   #5
wedgemon
wedgemon's Avatar
The pics save a LOT of bad words!! Thanks!
- Dave
Founding Member:
Old 10-29-2008, 09:46 PM   #6
joe231
joe231's Avatar
you can just pop the metal cover off and "reset" it, but as you stated, if you do it correctly, it saves the hassle
CHEVY ONLY
Old 10-29-2008, 11:15 PM   #7
BLE 'BURBAN
Reaally!? I've never even noticed that before!!! learn something knew every day. Too cool!!!
Old 10-29-2008, 11:20 PM   #8
joe231
joe231's Avatar
yeah
I've had to do it a couple time recently, cause I'm a jackass
CHEVY ONLY
Old 10-30-2008, 10:04 AM   #9
Eyegore
What Hump?
Eyegore's Avatar
Someone ought to save this as a sticky on the electrical forum, espically the pic.
This was real helpful - thanks guys.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 10-30-2008, 12:34 PM   #10
wedgemon
wedgemon's Avatar
Sticky time????
Founding Member:
