Old 10-29-2008, 04:30 PM   #1
1970heavychevy
busted knuckles
1970heavychevy's Avatar
Leaning a little
I cut 2 coils off and now I have a little gangsta lean. Has anyone else had this problem. I cut them the same on each side.
1970heavychevy is offline   Reply With Quote
Old 10-29-2008, 07:27 PM   #2
stefan
New Member
Re: Leaning a little
when i first lowered mine i cut two links and i had the same problem,a front end shop told me the springs were wore out and when you lower them its alot more obvious i called ece and bought springs and they told me the same thing,popped in new springs and the truck sat right,hope this helps.
stefan is offline   Reply With Quote
Old 10-29-2008, 08:27 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
x2
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-29-2008, 08:52 PM   #4
nuke1
nuke1's Avatar
make that 3
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-29-2008, 09:04 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Sounds like your springs are just worn out... call ECE (Early Classic Enterprises)
-Nate
Old 10-29-2008, 10:34 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Are you sure they are clocked correctly in the spring pockets? If one is not seaed in the groove it will make it sit higher...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
