Old 10-29-2008, 04:41 PM   #1
noteron
noteron's Avatar
Crossmember sectioning????
Would someone kindly post a "How-To" on sectioning the front crossmember. I have a spare truck that Id like to practice on... errr... hack to death... before I cut into my keeper 67 swb stepper. My goal is to lay it out & get my scrape on
noteron is offline   Reply With Quote
Old 10-29-2008, 05:11 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Crossmember sectioning????
It is the old way I used to do it, but it still is applicable:
http://www.captkaoscustoms.com/chopcross.html
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-30-2008, 11:22 AM   #3
noteron
noteron's Avatar
Thanks Capt.
Old 10-30-2008, 02:19 PM   #4
SCOTI
SCOTI's Avatar
Old way? Used to?
Did you change your methods or is the bolt-in crossmember frenzy slowing the demand?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-30-2008, 08:09 PM   #5
Captkaos
Captkaos's Avatar
Both, I changed the process of how I was chopping them. And yes Porterbuilts bolt-in has slowed demand a LOT, I only built 2 this year.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-30-2008, 08:29 PM   #6
noteron
noteron's Avatar
Can you explain in further detail what you did....
http://www.captkaoscustoms.com/images/crossalign2.jpg
What are your measurements on the verticle lines?
http://www.captkaoscustoms.com/images/crossalign3.jpg
And the horizontal lines?
What were your reference points?
Old 10-30-2008, 09:50 PM   #7
SCOTI
SCOTI's Avatar
I'm curious about the changes if you'd care to discuss.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2008, 11:27 AM   #8
Captkaos
Captkaos's Avatar
Keep in mind this was the first documented chop I put on the internet so I wanted to show how I was keeping the alignment of the top portion the same in relation to the bottom when I welded it.
The vertical lines have no measurements, they were laid out for reference marks ONLY. They are laid out across the outer portion of the mounting points for the frame on the left and right, and the middle was laid out across the center using the hole in the middle as a reference. Lines were punched into the the metal across these lines and then scribbed so when we started cutting the alignment could be reestablished.
The horizontal lines were masked from the top of the crossmember and the lower portion was set 1.5" below that point (this is the max you can go and not have steering issues) These were punched and scribed and then sections cut out at a time to reduce the heat.
I can expand on the 1.5" chop.
The way I lay the cut marks out now for a 1.5" is I mark the upper control arm line for an undercut, mask across that line with 1" tape and run it vertically down the front/back of both sides. Then using 1.5" wide tape I mask the area to cut horizontally at a upper section and lower section and then run a 1" wide tape mask 45 degrees across to make the 1.5" chop. With the 45 degrees it eliminates the need for alignment reference and the pieces will just drop straight down and align themselves.
I still sell these for $550 + the core.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-31-2008, 01:52 PM   #9
SCOTI
SCOTI's Avatar
I'm going to print that off, sit down looking @ a c.member, & see if I can figure out what you mean (it's not coming to me just reading it).
I have the original one I did using your original method & two other stock ones that I was thinking about modifying & selling @ a swap meet vs. chunking them for scrap.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2008, 05:27 PM   #10
Captkaos
Captkaos's Avatar
hmmm,
think of it this way. You have 3 pieces of 1.5" tape (6 for both sides)
you place 2 of those under the frame mount left and right, and you place another long one across the front. They are spaced to where the 1" tape will intersect both "corners" at a 45D angle (1" wide at 45D measured vertically = 1.5") If you got my number, just call me or email me. I don't have any pics of this method.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-31-2008, 05:52 PM   #11
SCOTI
SCOTI's Avatar
hmmm,
I have your number somewhere from the bumper exchange. I'll buzz ya' cause this seems interesting.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2008, 06:24 PM   #12
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Chris - Did you ever notice that the top of your chopped crossmember how to is titled:
How To's:
Blazer tank How-To:
, had to ask! I remember printing this off long ago, but I think I am going to give it a try for my 68. I have a couple extras that I can "practice" on.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-31-2008, 06:30 PM   #13
Captkaos
Captkaos's Avatar
hahahaha, nope. I created a template for all of those and forgot to change the title. I haven't updated that site in over 4 years.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
