Old 10-29-2008, 06:34 PM   #1
CAMAROSS
CAMAROSS's Avatar
Any help with a starter???
I didnt know where to post this so here goes. I have a big block (454) with a new flexplate (correct one) and a new starter. I cant get it to stop grinding and hitting the flexplate really hard. I have shimmed down, up, and no shims at all. Whenever you think its good, BAM! another grind. Any help?
CAMAROSS is offline   Reply With Quote
Old 10-29-2008, 10:51 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Any help with a starter???
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-29-2008, 11:01 PM   #3
boatpuller
boatpuller's Avatar
you might try asking in the engine and drivetrain section it may get more response.i didn't really have that problem but i had a heat related problem that i know 454's with headers suffer from..weak turnover when hot.i put on one of those little gear drive starters and that thing flat cranks hot or cold.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 10-29-2008, 11:05 PM   #4
ca180
tryin to get laid
Are you sure you have the correct starter? Perhaps it has a defect.
Logically thinking, if changing the position of the starter up and down has no effect on the grinding then maybe its "in and out" position is the problem.
Maybe the starter is too far in. There wouldn't really be a way of changing that because the starter bolts don't move back or forth.
So basically, the starter could be the problem. Does it have a warranty? Maybe you could exchange it for another one. I replaced a starter twice before I got one that was not defective. No lie.....
ca180 is offline   Reply With Quote
Old 10-30-2008, 04:27 AM   #5
bb1979
bb1979's Avatar
Had the same problem with mine. I've got a 454 with a T400 the biggest issue I had with aftermarket starters was the actual holes in the starter being cast in the wrong location, I ended up getting an original starter and replacing the nosing on the aftermarket one with the factory unit. Also get a starter motor brace, bolts onto the front of the starter and attachs to the block. The torque of cranking my motor over when the starter was shimmed correctly would cause the starter to move out of line and then next start bang ang clunk
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 10-30-2008, 06:54 PM   #6
CAMAROSS
CAMAROSS's Avatar
Thanks guys! Im going to try your advice. Keep your fingers crossed......
Old 10-30-2008, 07:08 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
My buddy had pretty much the same problem and did almost exactly the same thing and has absolutely no problems with the starter now!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-31-2008, 09:33 PM   #8
lurch115
lurch115's Avatar
okay...i know this might be a stretch but i have seen it so many times....are you sure that when you installed the flex plate that you didn't put it on backwards??? if you look around the center hole in the flex plate there is a little lip and that should be facing way from the block...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
