Old 10-29-2008, 08:33 PM   #1
bmrrwolfe
1970 C10
Relocating the gas tank?
http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245
I was looking at getting this kit, that is by CPP, but it says modifications are needed to mount it in the 67-72 truck, i was just wondering if anyone else has this kit (or similar) and what "modifications" are needed?
Also anyone have any good pictures of this or similar installed?
Thanks!
bmrrwolfe is offline   Reply With Quote
Old 10-29-2008, 08:44 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Relocating the gas tank?
I think if any it would include the following:
- drilling a few holes
- running new fuel lines
- I know on some of the aluminum you have to rework the rear crossmember (not the right term, drawing a blank...) on the frame
- possible notch, or bed modification for a filler
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-29-2008, 08:46 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here's a link that might offer some help....
click here
-Nate
Old 10-29-2008, 08:48 PM   #4
bmrrwolfe
1970 C10
Sounds easy enough, im not sure if i would want to put the filler in the bedside or just in the floor (i don't really plan on using the bed that much)
Old 10-29-2008, 09:00 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
There's also a few members on the board that have done this install, or a very similar one. Run a quick search through the board, and I know you'll find a ton of info on other custom setups.
Good luck with the project!
-Nate
Old 10-29-2008, 10:39 PM   #6
chevyboy55
chevyboy55's Avatar
There's a WHOLE lot more to it that what that e-bay ad says.I've done one.Here's a couple links to let you know what's involved.There a lot of work but pretty slick when they are done.
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
http://www.classicheartbeat.com/mark...t_gas_door.htm
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 10-30-2008, 12:31 AM   #7
2bits
2bits's Avatar
Yeah the modifications they speak of are the obvious... where are you gonna put the filler neck. You gotta run the lines things like that.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
