Centering the Rear End
I need to install my adjustable panhard bar and re-center my rear end after lowering. Should I measure from the frame to the brake backing plates? I tried search, but couldn't come up with it.
Thanks Mike
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES ![]() 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
A new C10 Addict!
Re: Centering the Rear End
That's what I did when I bagged my old Mazda and it set nice and center.
yes frame to backing plate or if you have tires on the sidewall to the frame/you need to have weight on the frame and rear to center correctly//i use a ratchet strap from the trailing arm to the oppisite frame rail to pull the rear over to get it centered while installing the panhard
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 10-30-2008 at 01:05 PM. |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Thanks guys. The rear end is siting on jack stands with the weight of the truck on it (along with all the crap in the bed) Should be enough weight, huh?
The strap is a good idea cdowns
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES ![]() 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape Last edited by MDC; 10-31-2008 at 03:12 AM. |
