Old 10-30-2008, 10:29 AM   #1
67chevemall
67chevemall's Avatar
Question 6 lug. distance lug to lug ??
Planning on ordering some wheels (finally)
what is the stock distance on 6 bolt rims lug to lug ? 5.5" ?
What is standard back spacing that would sit the wheel nice??
The truck is on bags.
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-30-2008, 11:13 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 6 lug. distance lug to lug ??
yes, that's the bolt pattern, 6 on 5.5.
As for backspacing, I have a statically-lowered truck with 15's. The fronts are 8-inches wide with a 4-inch backspace. The rears are 10-inches wide with a 5-inch backspace. The fronts clear the lower control arms without any issues.
Member Nr. 2770
Old 10-30-2008, 11:43 AM   #3
67chevemall
I'll have to do some measuring then for back space.....
One more thing does anybody know how many inches the center hubs are...Save me taking the tire off right now.
I think the front is the one that causes the problems....
Old 10-30-2008, 02:12 PM   #4
raggedjim
raggedjim's Avatar
Most aftermarket wheels for these trucks will have a 4" centerbore. The 78.3mm (about 3.08") wheels will NOT fit over the hubs! I have machined them to fit but it is a pain in the butt...
Just make sure the centerbore is over 3.825 and you fill be fine.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 10-30-2008, 03:30 PM   #5
67chevemall
3.825 sweet thanks man.
now just have to get this backspacing down......
6 lug 5.5" pattern
3.825 center bore
? backspacing They all seem to be from 4.5 to 6.2
Going with 18X 9-10 " rims
with 275/35/18 rubber
Old 10-30-2008, 03:55 PM   #6
raggedjim
raggedjim's Avatar
Well, I have 5" backspacing on my rearend and the tires are real close to the inner fenderwell. I would think you would be fine with a 4.5 but a 4 would be better...
Rg
Roger
'70 GMC Jimmy 2wd
Old 10-30-2008, 04:14 PM   #7
67chevemall
is that a 10" wide rim?
Old 10-30-2008, 04:23 PM   #8
raggedjim
raggedjim's Avatar
No. it's an eight, but a backspace is measured from the inside edge so a 5" backspace on an eight and a 5" on a ten will put the inside rim of the wheels in the same place.
Rg
Roger
'70 GMC Jimmy 2wd
Old 10-30-2008, 04:30 PM   #9
67chevemall
ah thanks. so measure from the front of the rim inwards.?
Old 10-30-2008, 04:41 PM   #10
raggedjim
raggedjim's Avatar
No, measure from the inside rim (toward the rearend) to the mounting face
See this link
http://www.classictrucks.com/tech/08.../photo_04.html
Rg
Roger
'70 GMC Jimmy 2wd
Old 10-31-2008, 11:10 AM   #11
67chevemall
Thanks guys...again...love this place.
Have my order ready to go!
Old 10-31-2008, 11:45 AM   #12
ZZ4Blazer
I dont know how much you read on that web page, but I just wanted to make a comment.
The top image is not correct. Rim width is not measured from the overall width. Rim width is measured from the inside measurement of where the tire mounts.
For example, if that rim(as pictured, without the tire) measured actually10" wide total, it should be labled as a 9" rim. Generally, the outer lip contributes 1/2" on each side to the wheel measurement.
However, wheel backspacing is measured to the outermost lip of the wheel, as pictured.
Just wanted to clarify. Hope that didnt confuse you any.
ZZ4Blazer is offline   Reply With Quote
Old 10-31-2008, 01:33 PM   #13
67chevemall
Thanks this one cleared it all up
Old 10-31-2008, 01:34 PM   #14
67chevemall
F would be the one ya mean...
Old 10-31-2008, 01:35 PM   #15
67chevemall
ZZ4 Blazer Akron.....my parents are over on Dewitt Dr...
Old 10-31-2008, 04:25 PM   #16
ZZ4Blazer
Yes!!! Exactly. Its not as critical with the fullsize being much larger, but I know on my s10, we like to cram as much wheel/tire under them as we can. That 1" difference from that pic being wrong is the difference between fitting, or cutting into the fender horribly.
