Old 10-30-2008, 12:07 PM   #1
67mater
67mater's Avatar
TWB driver quality parts if you got em
Give it a shot before I order, 61604. will order most of this within 10 days, so let me know. Thanks!
fuel filler hole rubber for a 72 cab/67 tank (what are the size differences?)
Driver's door latch hub with unbroken spring (part behind inside handle)
window crank with a black knob
upper and lower radiator hold downs for 4 core radiator
steering shaft rag joint
radio delete plate
parking brake cables and rods for 72 style brake/drums
72 manual pedal pads
license plate light sockets
door lock knob tops
cigarette lighter delete OR cigarette lighter knob
Dash pad black
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 10-30-2008, 12:31 PM   #2
roadmaSSter
roadmaSSter's Avatar
Re: TWB driver quality parts if you got em
radio delete plate
door lock knob tops
Dash pad black
I've got the parking brake hardware from pedal to drums. What rods are you talking about? Do you mean the ones that guide the cables or the the stamped steel pieces that are inside the drum going between the brake shoes? Anyways, the whole mess is yours for $10 plus my shipping cost. If you want to save on shipping, let me know what pieces you don't really need or you can take everything. I really doubt that the shipping costs more than $10 or $15. Gimme a shout. By the way, any decision yet on what weekend you are coming to TX?
The hole in the cab is the same size for 67-72, but there were two different filler neck sizes that I know of. One was 2" and I believe the other is 1 3/4", but I am not absolutely positive about the filler neck sizes.
-Ryan
roadmaSSter is offline   Reply With Quote
Old 10-30-2008, 12:38 PM   #3
67mater
67mater's Avatar
man, I just need to come with money and scout what all you got!!! i need everything form pedal to drum, and i was talkign about the guide bars off the frame
I am still lookign at the weekend before thanksgiving to come for bed, but as I said sell it local if you can.
thanks for info on tank neck, I'll measure mine.
1967 K10
1967 Camaro
Old 10-30-2008, 01:16 PM   #4
roadmaSSter
I am down to the bottom of the barrel as far as parts go. Here is what I can remember: outer door handles, parchment color visors, wiper arms, parchment seat belts (dirty), lots of misc. trim, small block engine stands, gmc steering wheel, set of rally wheels, inner door handles, hood, door & back glass, 70 wiring harness (good for parts), power brake booster and brackets (was new, but sitting for years), dome light (white, not chrome), cab vents, power steering box, and '70 1/2 ton frame with disk brake front end w/calipers, no rust (no rear end). There is a junk yard west of here that had a bunch of 67-72 chevy trucks a while back. Can find out if they still do. If you want anything shipped, send me your ZIP for a shipping quote or I can just hold it till you get here.
Thanks,
Ryan
Old 10-30-2008, 01:31 PM   #5
roadmaSSter
radio delete plate
door lock knob tops
Dash pad black
My '70 I used to drive had the smaller filler neck, but the PO did some odd ball things on it, so there is no telling if that was the original tank.
