Old 10-30-2008, 12:48 PM   #1
IhateUSERnames
Broke My Front Axel... Any Ideas
i borke the front driverside axel on my 1969 chevy c20 pickup... and now i don't know where to get one from. i was curious if any of u guys could help me out by maybe finding a new or used one.... and if any other chevy axels would fit into it... i'll try to get u guys a pic of wut i got, and what happened.
Cheers
Dan
IhateUSERnames is offline   Reply With Quote
Old 10-30-2008, 01:02 PM   #2
truckdude239
truckdude239's Avatar
Re: Broke My Front Axel... Any Ideas
is ti a solid axle?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-30-2008, 05:29 PM   #3
IhateUSERnames
yah it's a solid axel.... i spun the u joint out of it
Old 10-30-2008, 05:33 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Is the inner or outer axle broke or is it just the ujoint??
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-30-2008, 10:20 PM   #5
IhateUSERnames
i need the innner outer and u joint... i'll try to get a picture tommorw after work
Old 10-31-2008, 12:40 PM   #6
IhateUSERnames
heres some picture of wut i got going on. if u guys have anyideas on what i cna do that would be great
cheers
Dan
Old 10-31-2008, 01:42 PM   #7
Livrat
Member #1049
Livrat's Avatar
From your pictures that appears to be a 1977 Chevrolet Dana 44, Any Chev/GMC Dana 44 from 1971 to 1978 or 79 parts will fit,
I have been told some of the later (1979-83) 10 bolt parts will interchange too but can not confirm that.
Livrat is offline   Reply With Quote
Old 10-31-2008, 04:44 PM   #8
Jtrux
Jtrux's Avatar
If it's a 8 lug the outer axle stub shafts will be different too, make sure he gets the right one, shouldn't be hard at all.
Old 10-31-2008, 05:24 PM   #9
Longhorn321
Size Matters
Longhorn321's Avatar
I'm no help here but I gotta ? Wouldn't that be a K20? I thought that all 4 wheel drives were K trucks?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 10-31-2008, 05:42 PM   #10
IhateUSERnames
not entirly sure... new to the older chevys... i was told it's a c20... but dont; take my word for it... but it is a 8 bolt.... and livrat, u think it's a 1977 chev front end in a 1969?...... thats cool... anyone know where i cna get one for cheep... and also just incase i go to the scrap yard or anythign wut do i need to look for to find the same type of front axel
Old 10-31-2008, 06:08 PM   #11
msgross
msgross's Avatar
bad thing is that you have to pull the wheel, then lock-outs, then brake caliper, then hub, then spindle and then get the spindle off (that's the hard part). Then do that again in the junkyard and put it all back together... If you can find a matching dana 44 3/4 ton axle (8 lugs) then buy the whole thing (maybe $150?). Do all the work at home and keep the extra parts.
A newer 10 bolt won't work because the inner axle is different (length and spline count) so you have to find a Dana44 3/4 ton.
Or you could buy replacement axles and U-joints $$$ http://www.offroaddesign.com/catalog...axleshafts.htm
Try not to spin those front tires so much unless you go up to a Dana 60 ($900).
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-31-2008, 09:03 PM   #12
maximum destruction
In House Collision Technician
i always see posts on here saying a 10 bolt shaft won't work in a 44. in an emergency,(read trail riding this weekend),they will work! i've done it personally. the 10 bolt is shorter but only by a few fractions. i just leave out the outward most c-clip because the outer stub shaft is just shy of reaching. it has never hurt anything on mine. as far as spline count, i'm not sure on that but in my eyes, if the shaft goes in & the wheel pulls in 4x4, the spline count must be the same. lol
MAXIMUM DESTRUCTION
maximum destruction is offline   Reply With Quote
Old 11-01-2008, 08:39 AM   #13
msgross
msgross's Avatar
nope.. 10 bolt is 28 spline and dana 44 is 30 spline inner axles.... outer axles are the same...
I wouldn't think that a front axle would constitute an emergency that grinds your differental to shreds... but it's your truck...
The Garage:
Old 11-03-2008, 09:21 AM   #14
BIG HEAD
contact james FLORIDA POWERTRAIN
5625 SW 6TH PL
OCALA, FL 34474
866/267-8006
oclsales@floridapowertrain.com
THEY ARE A DANA/SPICER DEALER AND GIVE GREAT PRICES AS WELL. NOT TO MENTION JAMES MAKES THE BEST DRIVE SHAFTS AROUND.
BIG HEAD is offline   Reply With Quote
