10-30-2008, 01:27 PM | #1 |
Brighter Lights: Highly recommend the following product from LMC
I know it is posted in the forums...how to get brighter headlights. I just wanted to post the following.
Instead of making the harness from scratch, I ordered it from LMC part #36-3581 $29.95 It is basically a plug and play system. Complete with OEM connectors. Disconnect headlight nearest battery, plug in harness....yadda yadda Mount two relays, connect power, ground voila! Man what an easy install and the difference in brightness was amazing. |
10-30-2008, 01:44 PM | #2 |
Between Trucks...
Re: Brighter Lights: Highly recommend the following product from LMC
I got this setup as well. Works great and is easily reversible if for some reason you'd want to go back to stock.
Beat it to fit, Paint it to match... |
10-30-2008, 02:01 PM | #3 |
Looks like 36-3581 is GMC and 36-3580 is Chevy. Same price, this is a case where you'd think GMC would cost a bit more
I looked at the several different threads with homemade/junkyard/autozone stuff a few times and it looked to be a bit of a pain... I like plug and play better, especially for wiring. Plus, I could actually use new headlight sockets anyway... Are the relays BOSCH?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-30-2008 at 02:04 PM. |
10-30-2008, 02:03 PM | #4 |
Sierra Grande Club
I ordered a complete M&H engine & forward lamp harness from Wes (Classic Heartbeat). It has the upgraded relays. I noticed it gets its power from the positive battery lug on the starter, brings it over and down to the headlights. This is going to look real clean.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
10-30-2008, 02:47 PM | #5 |
Got a picture of it installed? I am curious to see the routing...
10-30-2008, 06:33 PM | #6 |
Engine n00b
I have the same kit and love it pics of the install:
Far from a PRO install, but you get the idea. Pass side DS: |
10-30-2008, 06:35 PM | #7 |
Engine n00b
My *only* complaint is the thick yellow part was not QUITE long enough for the over the radiator run.
Instructions are MOSTLY in asian other than a diagram, so there wasnt any routing specifics. |
10-30-2008, 09:22 PM | #8 |
Thx for the pix!
10-30-2008, 09:22 PM | #9 | |
Sierra Grande Club
s/t
10-30-2008, 10:11 PM | #10 |
Engine n00b
BTW, somewhere in the FAQ is a thread on how to relay this on your own, if you are electrically and search inclined.
10-31-2008, 04:16 AM | #11 |
"THE GREEN GOBLIN"
I have the same one #36-3580 about to do this No directions that I can read on the pakage! These pictures are great I guess it is easy after all!!!
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
10-31-2008, 11:38 AM | #12 | |
The Older Generation
LockDoc
10-31-2008, 04:25 PM | #13 |
its all about the +6 inches
I've heard quite a few complaints about this product from LMC... junk relays, and crappy quality on the harness.
This is pretty easy to do yourself, it'll hide better (why use yellow??? Yellow is SRS/airbag stuff in the automotive industry) and you control the quality instead of expecting a quality product and not getting one. |
10-31-2008, 06:16 PM | #14 | |
Moderator
10-31-2008, 06:55 PM | #15 |
I'll see if I can locate a good thread or do my own, but, it'll have to wait till saturday or sunday, I'm doin one more lap around the board then crashing. I'm BEAT!
10-31-2008, 07:12 PM | #16 |
Moderator
No worries...get some sleep! That factory extended cab truck you just helped go get looks awesome!
