Old 10-30-2008, 01:56 PM   #1
davidh
davidh's Avatar
rear end code?
I need this code deciferd. Came from a 80's 3/4 4x4 truck RHMG2251. It looks like the light duty rear end as the axles arent full floater.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 10-31-2008, 12:01 AM   #2
davidh
davidh's Avatar
Re: rear end code?
anyone?
Old 10-31-2008, 12:44 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: rear end code?
you would have a semi floater if i'm not mistaking and if it doesn't have 14 bolts on the pan it would be a 1/2 ton or 5/8 tons "big 10 or heavy half"
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-31-2008, 03:22 PM   #4
davidh
davidh's Avatar
Re: rear end code?
its a 8 lug 3/4 ton but its flat on the axle ends, not bulged like a floater
Old 10-31-2008, 03:27 PM   #5
Cyclone
Cyclone's Avatar
Re: rear end code?
+1 on the semi float, some ID info here
Cyclone is offline   Reply With Quote
