Old 10-30-2008, 02:36 PM   #1
Slik69
disc brake conversion
A friend has a pair of disc spindles and wants $100 for them. He mentioned these originally had 5 lug rotors on them which were thrown away because they were no good. My truckis 6 lug pattern which I would like to keep because I already have wheels I like.
Can 6 lug rotors be bought and put on these spindles. Also, I already have power brakes. What else is needed if these will in turn work.
Slik69 is offline   Reply With Quote
Old 10-30-2008, 02:44 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: disc brake conversion
i am not certain, i believe if your going 6 lug disk rotor it should work. you could also Call ECE 1.888.777.0395 as they sell the 6-lug disk conversion and would know if the spindles are compatible.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-30-2008, 03:57 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I think on most of the disc conversions(after market) they use a 71 up spindle and then vary the lug patterns.You should be able to the get rotors you want by contacting one of these co. You will also have to change the ball joints and tie rods.
sneakysnake is offline   Reply With Quote
Old 10-30-2008, 04:38 PM   #4
70GMCer
70GMCer's Avatar
GMCPauls has the best price for 6 lug rotor kits. And you will have to change the ball joints/tie rods ends.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-30-2008, 05:58 PM   #5
cparman
sharp as a marble
I bought two six lug rotors from Master Power brakes. As long as the wheel bearings are the same ( between 5 lug & six lug ) the should interchange.
cparman is offline   Reply With Quote
Old 10-30-2008, 06:47 PM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
It depends on what year the spindles are. If they are from a 71-72 then the disk brake conversion spindles will work. Like sneakysnake says you will have to change the upper and lower ball joints, and left outer tie rod end also. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-26-2008, 12:05 PM   #7
memphismatt
memphismatt's Avatar
I am about to do the same thing. Which ball joints and tie rods should I buy? The ones for the '71 the spindles came from? or my '67? this probably a dumb question but i don't want to go to the parts house twice.
'68 C 10 short step
'92 C1500 RCSB
'92 C3500 ECDRW
'96 C1500 ECSB
memphismatt is offline   Reply With Quote
Old 11-26-2008, 12:15 PM   #8
71tahoe
71tahoe's Avatar
Get the parts to match the '71 spindles.
71tahoe is offline   Reply With Quote
Old 11-26-2008, 12:29 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I know he's your buddy and all, but 100 is too much for a set of non dropped spindles. 25 to 50 is more reasonable.
Old 11-26-2008, 12:59 PM   #10
Cyclone
Cyclone's Avatar
Exactly what I was thinking as I read this.
Cyclone is offline   Reply With Quote
