Tire Diameter or Size Question 72 GMC 4x4 (stock)
I'm looking for what the original equipment tire diameter was on a 72 GMC 3/4T 4x4. I need to do some math to figure out how far off the speedometer is but I need to get the starting point...
TIA |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Tire Diameter or Size Question 72 GMC 4x4 (stock)
May have been optional sizes... Should be the same as my '72 K20, though. It came with 7.50-16s, about 31.8" tall iirc. Armstrong Norsemans (traction) in that size were 32.2", again if my memory is correct.
A bit of searching indicates 265/75-16 may be close to the same diameter as the OEM bias-ply tires. If you don't have them already, here's a couple of calculators: http://www.discounttire.com/dtcs/infoTireMath.dos http://www.miata.net/garage/tirecalc.html
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 10-30-2008 at 10:28 PM. |
Thanks. That gets me a start on how much my speedo is off.
