It followed me home?
Carpet, sound deadener install help
I'm ready to install a new carpet kit and a couple rolls of sound deadener in my truck and blazer and I'm not exactly sure what I know what I'm doing.
Does the carpet need to be glued down? The kit I got for my truck is not molded so I thought it would be best to glue it down to the sound deadener to make sure there are no wrinkles and just toss the factory mat out. My blazer kit is molded so I dont think it will need to be glued but I really want to make sure there are no wrinkles etc. Any tips, ideas?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Re: Carpet, sound deadener install help
for no wrinkles, molded carpat is what you need, if you don't have that, glue will be needed to hold the curvatures of the floor. With creative trimming, you can make flat carpet look good, but it will take a while to do.
#3 | |
Low & Fast!
Happy to be here
![]() Join Date: Mar 2000
If the factory mat is in good condition, you might be able to glue the carpet to it. In case you need to remove it, it would still come out. Either way, use the mat as a template.
Dark Heart Motorsports
x2 on the template idea...
spray adhesive in a can is pretty easy to use once you get to the step of installation for the carpet. prior to that, you can find aluminum tape (carpeting tape) from JCW, autozone, advance, orielly's; for your padding. use it by taping down the outskirts of the padding, and any centerline cuts or modifications with spray adhesive on the underside for a firm hold.
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
