Old 10-31-2008, 03:06 AM   #1
Rack Man
Different Axle Widths (Track widths)...??
As part of my frame-off resto. on my 70 K10, I located a later model Dana 44 with disk brakes and just scrapped my other drum brake Dana 44 axle (as it was trashed anyways)
Now that it is back together I was noticing that the front axle is actually quite a bit wider than the rear....is this normal?.....I didn't notice it before....so maybe my old one was the same.....I'm a little perplexed that the front is over 3" wider than the back....
Front measures: 67.5"
Rear measures: 63.75"
(that's flange to flange)
Can anyone shed some light on this?
Thanks, Dan
Here they are all cleaned up and looking purty!
Rack Man is offline   Reply With Quote
Old 10-31-2008, 06:48 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Different Axle Widths (Track widths)...??
Thanks, Dan
That is the way they built them. Your original front axle was the same length as the one you have in there now.
Blazer1970 is offline   Reply With Quote
Old 11-01-2008, 08:35 PM   #3
va_tlc
va_tlc's Avatar
i agree, and that shop is way to clean, lol looks like a very nice job you done on restoring the axels.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 11-01-2008, 09:08 PM   #4
arkracing
Weekend Warrior
Yeh If you look at any pre '87 Solid Front axle truck the fronts are all wider. Helps with turning radius
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-01-2008, 09:16 PM   #5
msgross
msgross's Avatar
I ended up using a 2WD 12 bolt in the rear and noticed that it's a little wider than the original 4wd 12 bolt...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
