Old 10-31-2008, 04:13 AM   #1
LeDevil
A new C10 Addict!
LeDevil's Avatar
Which HEI.....
I'm wanting to swap out my points distributor for a HEI set up. I was wondering what year/model vehicle is the best to swap over to so I know what I should be looking for at the yard to get the distributor out of? I did a search and couldn't find anything so if any of you know a link off the top of your head feel free to post.
Thanks LeDevil
LeDevil is offline   Reply With Quote
Old 10-31-2008, 06:23 AM   #2
R.L.
R.L.'s Avatar
Re: Which HEI.....
I'm not sure but I think there all the same as long as you rob one of the same type motor,SB, BB, L-6.
R.L. is offline   Reply With Quote
Old 10-31-2008, 06:52 AM   #3
lax54650
Re: Which HEI.....
check out skip white on ebay he has a complete hei billet with cap rotor coil new for $49 has anyone used it? is it good? sounds too good to be true. has 2 year warranty. i need one too have been debating is it worth it? i believe if you buy used rebuild it you might have more than that in it
lax54650 is offline   Reply With Quote
Old 10-31-2008, 07:11 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Which HEI.....
Wow, that's cheap!
I bought an ACCEL from O'Reilly's for $120, after giving up on the junkyard unit that was in my truck. It's not just the module, rotor and cap that can give you trouble, but also the pickup coil and the bushings. These are items that a new/reman will have that have been replaced in the reman process. When the wire to the pickup coil breaks, you have to pull and disassemble the unit to fix it.
Member Nr. 2770
Old 10-31-2008, 09:57 AM   #5
Hawker7
Re: Which HEI.....
+2 on skip white on ebay. Great price and fast shipping. Many people have run his HEI's with no problems.
Hawker7 is offline   Reply With Quote
Old 10-31-2008, 10:40 AM   #6
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Re: Which HEI.....
Thanks LeDevil
I'm fairly certain HEIs are pretty much all the same. You can get billet ones, install hotter coils, or different advance weights and such, but essentially, they're all the same. The quality of the parts they're built with does have an effect on how they run, as well as worn out bushings.
Lugnut64052 is offline   Reply With Quote
Old 10-31-2008, 01:57 PM   #7
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Re: Which HEI.....
I've bought 2 from Skip White on ebay. The only problem I've had was one of the modules didn't last 500 miles. Quality seems good to me. He sells a good set of plug wires too.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 10-31-2008, 02:15 PM   #8
70rs/ss
70rs/ss's Avatar
Re: Which HEI.....
You can't rebuild an old HEI for what the skip white one costs, so that is a no brainer there. If the modules burn up, i believe he has a one year warrantee as well, just send it back.
70rs/ss is offline   Reply With Quote
Old 10-31-2008, 02:49 PM   #9
Rreemo
Rreemo's Avatar
Re: Which HEI.....
Another vote for Skip White - he sells good stuff. I bought a set of those Wysco roller rockers that he has....was extremely impressed with the quality. They are every bit as nice as the big named stuff that I have used in the past.
And just to answer a question above.....SBC and BBC take the same distributor.
72' LWB Cheyenne
73' Camaro Z28/RS
70' Chevelle RagTop
00=ss=00
Rreemo is offline   Reply With Quote
Old 10-31-2008, 03:13 PM   #10
70rs/ss
70rs/ss's Avatar
Re: Which HEI.....
http://stores.ebay.com/whiteperforma...meZL2222QQtZkm
Here's the link to his store.
Old 10-31-2008, 03:17 PM   #11
Lugnut64052
Re: Which HEI.....
True.
Except for the two tall block BBCs, the 366 and 427 truck motors. Otherwise, all Chevrolet small block and big block distributors will interchange.
Old 10-31-2008, 06:58 PM   #12
LeDevil
A new C10 Addict!
LeDevil's Avatar
Re: Which HEI.....
Thanks guys I thought they were all the same but I was told by a couple people they weren't so I started second guessing my self. Appreciate the help.
Old 10-31-2008, 07:10 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Which HEI.....
another for skip white, installed one the day I picked up the burb last year. The diaphram in the vac advance popeped, but otherwise, no issues.
Old 10-31-2008, 08:08 PM   #14
lax54650
Re: Which HEI.....
i guess i will order a skip white one then thanks ledevil for startin this thread
Old 10-31-2008, 08:21 PM   #15
jorgensensc
jorgensensc's Avatar
Re: Which HEI.....
another skip white buyer here. Bought 4 and one developed a problem. I called him up and he had a new replacement at my house in 2 days. I then shipped the old one back in the same box. Good customer service. Jmho.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-31-2008, 08:26 PM   #16
lax54650
Re: Which HEI.....
is this the one i need? SBC BBC CHEVY HEI DISTRIBUTOR 65K COIL RED 8909R
Old 10-31-2008, 09:01 PM   #17
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Which HEI.....
+ 1 I have a Skip White unit as well. My truck isn't running yet (still building).
But I have a question for you guys that had problems with this HEI.
Do standard HEI parts interchange with this unit?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-31-2008, 09:37 PM   #18
Boog
laying low
Boog's Avatar
Re: Which HEI.....
Originally Posted by lax54650 View Post
I think that is the one he ran last month as a "pricing war" sale. Not to be repeated, limited time while they last.
I looked at that one hard myself. I could not find a single HEI in the Summit catalog with a 65,000 volt coil comparable to his. While I was trying to find one to compare it with in the catalog the last 2 sold before I could get one.
If he sells them every day for $49 and they are brand new units it has to be missing something when reman'd factory units are going for over a $100. Don't ya think?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-31-2008, 10:42 PM   #19
lax54650
Re: Which HEI.....
*the add says its all there... but
Old 11-01-2008, 10:14 AM   #20
Sinister
Between Trucks...
Sinister's Avatar
Re: Which HEI.....
I got a fleabay HEI, not a Skip White though. Had it about a 2 years, runs great, zero problems.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-01-2008, 05:23 PM   #21
LeDevil
A new C10 Addict!
LeDevil's Avatar
Re: Which HEI.....
Thanks for all the good info and help guys it been appreciated. When I get done doing a few other upgrades I think I'll go with a Skip Whites Distributor but for now it looks like I'll be getting a good HEI from a fellow board member.
