Old 10-31-2008, 06:58 AM   #1
eric67m
eric67m's Avatar
Dana/Corp parts compatability?
Are any parts compatabile between a front Dana 44 and a Corperate 10?
Im wondering if I could make a 6 lug 44 into a 8 lug with parts (spindles, rotors , brakes) from a 8 lug corperate 10?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 10-31-2008, 08:18 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Dana/Corp parts compatability?
Yes you can do that. I think the axle shaft splines are different. And the center link comes up from the bottom instead of down from the top. But you could use the D44 knuckles. And the brake caliper hoze is different. I would try to get the whole axle and use what i needed.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-31-2008, 08:57 AM   #3
FormerMember
Yes, take from the outer knuckle out.
FormerMember is offline   Reply With Quote
Old 10-31-2008, 06:53 PM   #4
eric67m
eric67m's Avatar
So it sounds like I would loose the flat top knuckle from the dana 44. If I swap from the knuckle out. Can the Corperate 10 be converted to cross over steering?
Old 10-31-2008, 08:00 PM   #5
FormerMember
Yes. You can also compare the knuckles. I think the spindle bolt pattern is the same. Just be sure to match the brake bracket, brakes and spindle to the hubs/bearings.
Old 10-31-2008, 08:15 PM   #6
msgross
msgross's Avatar
major differences are the INNER axle splines and length, caliper banjo bolt is metric, axle tube is wider
spindle and out (if you want to keep your knuckles) should all be the same. Outer axle shafts might be different between 1/2 ton and 3/4 ton. But you can use the one's from the corp10, just change at the Ujoint.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
