Old 10-31-2008, 07:08 AM   #1
eric67m
eric67m's Avatar
Torque bracket mounting
On my 67 K10 with a NP205 transfer case there is no torque bracket. I assume that this truck originally had a timken (211 or 221?). When the PO swapped in the 205 they did not use the torque bracket and there are no holes in the frame .
To drill the holes in the frame should I ...
Bolt the bracket to the transfer case, bolt the two halfs of the bracket together, mark holes on inside rail of frame, remove tranny/transfercase(replacing anyway), drill holes in frame, reinstall new tranny/transfercase?
OR
Is there a way to measure/drill from the outside of the frame? Does any one have dimensions?
Eric
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 10-31-2008, 08:12 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Torque bracket mounting
I would do plan A.
Since it did not come with a 205.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-31-2008, 08:26 AM   #3
drbyrdman
drbyrdman's Avatar
everyone I know takes the bracket off. it will break your tranny and other stuff if you off road alot or have a big horsepower engine. just put poly engine and transfercase mounts and you are good to go.
drbyrdman is offline   Reply With Quote
Old 10-31-2008, 11:06 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
I run one on my race truck and i have NEVER broke my tranny or other stuff because of running a torque mount. I have seen the crossmember , adapter feet broke off from not running one. I also seen motor mounts broke from not strapping down the driver side of the motor. When that broke the fan wiped out the radiator.
The GM engineers put a lot of time and money into figuring this stuff out.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 10-31-2008, 11:42 AM   #5
OrrieG
OrrieG's Avatar
I have seen pictures of 4WD TH350 cases cracked at the area above the fluid lines from excessive engine torque. I run a chain from my frame to the side motor mount that allows about 1/2" slack for around town but limits movement when romping in the woods.
I'd go with method A too, on my truck I had to fab a bracket and did what you outlined.
OrrieG is offline   Reply With Quote
Old 10-31-2008, 04:48 PM   #6
eric67m
eric67m's Avatar
I have driven it on roads for the last 2 years, a few heavy loads but never off road or flexed it much. Since the new tranny/transfer is going in I figured I would make it correct. No point in pushing my luck.
