Old 10-31-2008, 12:48 PM   #1
baggedcten
86 C10
baggedcten's Avatar
Question How do You extend
the rubber fuel lines,ones from the fuel tank, what is the best way to extend them? I'm thinking of cutting them and placing some sort or pipe or fuel line inside and using hose clamps (don't know if it makes sense) but would it leak?
Thanks.
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 10-31-2008, 01:02 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: How do You extend
they sell fuel lines in the auto parts store you can get.. id try to keep it as much steel as you can tho.. you can use unions to joun steel lines
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-01-2008, 12:05 AM   #3
pezzy
pezzy's Avatar
on the few lines that i've kinked while screwing around with them, I've just cut the metal line on either side of the kink with a pipe cutter and relaced the section with a piece of rubber fuel line that you can buy at parts stores and put clamps on it. Never had a leak yet
pezzy is offline   Reply With Quote
Old 11-02-2008, 12:18 AM   #4
baggedcten
86 C10
baggedcten's Avatar
Thats sounds like what i want to do cut the metal line and use rubber fuel line to extend them but just wanted to know if it would leak or not.
1986 C10
Old 11-02-2008, 06:47 AM   #5
grinch4om
dang its hot
grinch4om's Avatar
look closely at sources of rub through and ignition!!! you don't want to fix cheaply the fuel system! buy the tube bender if kinking is a problem
grinch4om is offline   Reply With Quote
Old 11-02-2008, 04:30 PM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I always use two hose clamps just in case, but no it won't leak. I've done this several times.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-04-2008, 12:23 AM   #7
baggedcten
86 C10
baggedcten's Avatar
thanks thats what i wanted to hear!!
1986 C10
