10-31-2008, 06:09 PM | #1 |
New question to the rocker panels
Can anyone tell me on the floor at the rocker where your inside cab weather striping goes is that the complete rocker panel that i need to replace if the lip for the weather striping is rust off??? Here is a pic of what i'm asking about
10-31-2008, 06:30 PM | #2 |
Re: New question to the rocker panels
Yup that lip is the top of the outter rocker panel.
10-31-2008, 06:39 PM | #3 |
they make a smaller, slip on rocker if you want a quick and dirty solution and the rest of the rocker is good
CHEVY ONLY Last edited by joe231; 10-31-2008 at 06:39 PM. |
10-31-2008, 07:58 PM | #4 |
Like said above the rubber goes on the lip. IMO it looks like you need more work than just the rockers once you get into it. The floor looks pretty rough to me in the photos. We have left the rockers alone on some budget jobs and just bent and welded in the lip portion. However you need good steel to weld to. We hardly ever use a slip on anymore but it would work. I just don't like them as much. But heck it depends on the budget and what you are doing with tghe truck
10-31-2008, 08:35 PM | #5 |
One day...
There is also a flat piece that goes in behind the rocker you will need also unless you can get the rocker off without tearing it up too bad
10-31-2008, 09:58 PM | #6 |
So is the only two pieces i'll need is the inner rocker and outer complete rocker panel? I already have the floor pan just pulled the weatherstip off that lip and saw the rocker eaten up to.I just want to make sure that when i order from LMC i get everything i will need.Here is the list of rockers they have can someone suggest what all i need to be safe?Thanks Shaun
1 inner rocker panel 2 partail rocker panel 3 outer rocker panel 4 plug-rocker panel access |
10-31-2008, 10:37 PM | #7 |
here are a couple other pieces you might need
outer cab floor rocker backing panel/ inner rocker cab support are you set on LMC? check out tri-pro automotive 60-66 parts LINKY or classicparts.com
CHEVY ONLY |
11-01-2008, 10:02 AM | #8 |
If you are replacing the inner rocker I would use the newer ones that came out earlier that go from pillar to pillar. That flat plate one is a piece of crap. It doesn't cover the whole area and reach the pinch weld on the lower edge very well. The newer style is good. it makes the job alot easier and cleaner to.
11-01-2008, 12:05 PM | #9 |
FYI have you read LFD's thread on rocker replacement in th FAQ? He has a real thourrow article. Not same year but same method
http://67-72chevytrucks.com/vboard/s...d.php?t=271066 |
11-01-2008, 06:30 PM | #10 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
11-01-2008, 07:28 PM | #11 |
One day...
I got my rockers from lmc had to do some trimming but other than that they fit pretty good.
11-02-2008, 07:00 PM | #12 |
That cause they are from TriPlus most of the time. Same stuff we sell and many other suppliers. LMC buys from the same companies we do.
01-10-2009, 08:56 PM | #13 |
ok heres what mine look like, what do you all think I would need to fix it up,Thanks for your help,, (right side)
(Left side)
Check out my Photos http://67-72chevytrucks.com/gallery/...ry.php?cat=769 L.L. N.M. 63 chevy c-10 67 chevy c-10 71 chevy Blazer 4x4 |
01-10-2009, 09:26 PM | #14 |
your floor looks like its a later model truck than a 60-66. Generally the seat area is flat instead of the two humps.
01-10-2009, 09:27 PM | #15 |
I was checking out the link that was posted here, I kinda thing mine is probably in the same shape as that guys, haha I think I'll need everything, but can you all give me the names of the parts I might need,, thanks a bunch..
01-10-2009, 09:27 PM | #16 |
sorry its a 1967 c10
01-11-2009, 12:25 AM | #17 |
maybe you have realized this......but you are in the wrong section
you will probably get a better response over in the 67-72 section
CHEVY ONLY |
01-11-2009, 10:28 AM | #18 |
UCA63
My '63 GMC has the same trouble,rockers are solid with exception of the weatherstrip lip.
I have discovered that the contour of drivers rear radius is the same as the passengers front and from what i've seen the rears are usually not rusted. My parts truck will be donating this section Hope this helps T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
01-11-2009, 12:37 PM | #19 |
Its kind of hard to tell from a pic the extent of any rust but it looks like you could get away with just using the full length "outer floor extension" see picture. There is also a picture showing the coverage from the inside edge of the little drop down where the sill plate goes. Its about 2.5IN. You will also need an outer rocker panel at minimum. The rest is hard to tell without more photos. We sell all the parts as well as most of the vendors on here.
http://estore.websitepros.com/126980...SEC/Detail.bok These are fairly easy to put on with a few skills Last edited by mbgmike; 01-11-2009 at 12:38 PM. Reason: added phto |
