Old 11-01-2008, 01:06 PM   #1
Husker
Husker's Avatar
Which Carpet..
I need some carpet for my truck 70 GMC4x4 4 speed without fuel tank in cab.
ACC does not make it without fuel tank or Trim Parts they have some for that application. I want to go black.
Anyone use Trim Parts with good results?
I may also make some kind of speaker panel to go back there so I might be able to use use ACC. Anyhow anybody have feedback.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 11-01-2008, 01:20 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Which Carpet..
Seems to me that we have at least one vendor on-site who sells the TrimParts brand. So, ACC doesn't sell carpet w/o also including the cover for the gas tank? I thought that I had seen the carpet in a stand-alone sale, and the gas tank cover and kick panel carpets were extras.
Member Nr. 2770
Old 11-01-2008, 02:59 PM   #3
Husker
Husker's Avatar
Re: Which Carpet..
The Trim Parts one just covers the floor area where the Fuel tank sat. To cover back wall you have to buy that peice separatley.
Who sells the Trim Parts?
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-01-2008, 03:52 PM   #4
mbgmike
Re: Which Carpet..
We are dealers for Trim Parts or you can buy direct from them. We are a little less expensive. Overall i like their carpet. I would suggest getting the floor mats also cause like most repro carpet it will wear quicker than most OEM carpet. I have heard the GM is going (GREEN) with carpet made from recycled plastic bottles.
mbgmike is offline   Reply With Quote
Old 11-01-2008, 03:57 PM   #5
Husker
Husker's Avatar
Re: Which Carpet..
Mike How much for a High Hump without fuel tank? Also does this cover entire area from sill plate to sill plate? There will be no exposed areas?
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-01-2008, 04:37 PM   #6
mbgmike
Re: Which Carpet..
Yes is will cover the entire floor. You will have to trim it at the rockers and the back corners as it will be about 3inches oversized along the sides. You have to cut your own dimmer switch hole and add supplied grommet. ALong the sides at the front at the kick panels they usually have a binding sewn on.
They do not come with any jute if you are planning on using it.
I know they have went up on the prices and I will get Jennifer to call them and see what the price increase is. We will still be less than buying direct.
If you want to do the back of the cab, we do this all the time on these trucks with a variety of materials. We just build an aluminum framework and attach wood or plastic panels and use just about any kind of material. They are held on by Christmas trees and can be removed.
Old 11-03-2008, 07:58 PM   #7
mbgmike
Re: Which Carpet..
Ron
Hey Ron
It would cost $150.00 shipped to your door
Old 11-03-2008, 08:42 PM   #8
Chevy4Life
Chevy4Life's Avatar
Re: Which Carpet..
Check out www.stockinteriors.com You can order free samples. I got them in like 3 days. I just ordered my carpet this weekend, comes with jute backing and other upgrades are available. I ordered a low hump, tank removed. Mine was $129.15 shipped. I should have it in a couple days, but I won't be ready to install it for a week or two.
Jay
Chevy4Life is offline   Reply With Quote
