Old 11-01-2008, 08:03 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
block lift
allright guys i'll finally admit that my stubborness over addaleaf to block lift is finally over. My truck with it's add a leaf is just to "jittery" for city streets and decided to jar my spine whenever i go wheeling..
soo where is the reccomended place to get a simple block lift to replace my add a leaf?
im only lookin at 2 in.. or 3.. not sure...
thanks!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-01-2008, 08:24 PM   #2
mstrav1973
mstrav1973's Avatar
Re: block lift
Just buy one from 4-wheel parts. you will need the u-bolt kit to go with it.
matt
mstrav1973 is offline   Reply With Quote
Old 11-01-2008, 08:47 PM   #3
Cyclone
Cyclone's Avatar
Re: block lift
Got some 2 1/2" blocks for sale $40. shipped (lwr 48)
Cyclone is offline   Reply With Quote
Old 11-01-2008, 10:50 PM   #4
dammitmitchell
the pollock
Re: block lift
front and rear? i would like both..
Army vet 02-08
Old 11-01-2008, 10:54 PM   #5
FormerMember
Re: block lift
Please don't run blocks in the front. They tend to spit out, as your front end sees allot more rotational force. When a front block spits out, it's really not purty.
FormerMember is offline   Reply With Quote
Old 11-01-2008, 10:55 PM   #6
Cyclone
Cyclone's Avatar
Re: block lift
Just have these rears.
I read somewhere that using blocks on the front is not safe.
Old 11-01-2008, 11:10 PM   #7
ERASER5
ERASER5's Avatar
Re: block lift
AutoZone has lift block kits for about $25. The blocks are aluminum.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-01-2008, 11:13 PM   #8
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: block lift
Most states front blocks aren't legal...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-01-2008, 11:25 PM   #9
dammitmitchell
the pollock
Re: block lift
ahhh allright
guess i'll jsut ron some ont he rear.. it'll be a short while before i do actually get off myb utt to do it though... it's mainly the rear end that dances... thanks for the input
also my truc never sees any well. "heavy duty" use besides mudding ..
it's my pretty baby for destroying perfectly good ground =-)
Army vet 02-08
Old 11-02-2008, 08:50 AM   #10
FormerMember
Re: block lift
Doesn't matter, that force I was talking about? It's from steering.
Seriously.
Old 11-02-2008, 09:59 AM   #11
LONGHAIR
Re: block lift
What brand of Add-a leaf kit did you use? I have never heard of anyone complaining about them, other than they should have gotten a lift kit instead, because it wasn't high enough.
As the others have said, no blocks on the front. They are not safe in the first place, and every one I have ever taken off has been a tapered block too. This is doublly wrong. The blocks amplify steering forces just being there, but when tapered blocks are used to tilt the pinion up, they change the caster angle of the steering. Negative caster will make the truck hard to drive. It will wander all over the place and the steering will not want to re-center after a turn.
IIRC, you have already broken an axle in this truck, which leads me to believe that you are pretty aggressive with this truck off-road. This is an even better reason NOT to use blocks.
LONGHAIR is offline   Reply With Quote
Old 11-05-2008, 05:19 PM   #12
dammitmitchell
the pollock
Re: block lift
well im nto sure which one it is really (long hair) and good memory dude..
i put the leafs on a while ago for my buddy and put the motor in for him, but i wasnt the one buying the parts, but i put them on... diddnt ahve a interest in buying the truck from him when i was doing the work.
my major complaint is that the rear dances entirley too much when braking in regular road traffic,
i have the axels n brakes off an 84 suburban, so they r corp 10 front, and 14bolt SF rear, im running procomp 37' radials (which i kinda regret but i got all starreyed and just had to have them) but these tires r bad ass.. to say it politely..
so what then is causing my truck to be so spine jarring while driving?
oh tire pressure is down to 35 psi as per reccomendations of procomp.. it helped but not alot
Army vet 02-08
Old 11-06-2008, 11:58 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: block lift
To help you out and make sure you stay away from blocks in the front, I'm gonna offer you a used set of 73-up front springs for free, you pay shipping. These springs were on my 70 K5 when I bought it and although I have no idea of the manufacturer, I'm sure they must be 4" springs for the 73-up as they are longer than they should be for a 70 truck. I have no idea how old they are and when I removed both springs I had to cut the front spring hanger bolt as they were seized in the spring. As such, you would have a little work ahead of you getting the cut, seized bolts out of the front spring eye. PM me if you want these and I'll give you a rough guess on what shipping would run you.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-10-2008, 09:54 PM   #14
dammitmitchell
the pollock
Re: block lift
this sucks!
i cant work on my truck im stuck in illinois!
but thansk for you help and suggestions guys.. i wont be doing anything probably until the new year...
but i'll definatley hit yall up for block for the rear... thanks for your time
Army vet 02-08
Old 11-10-2008, 10:06 PM   #15
msgross
msgross's Avatar
Re: block lift
there are short and long add-a-leafs... longer would be smoother I would guess. combine those with an ORD zero-rate leaf and you can get 2-3" easily... and safely
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-12-2008, 12:17 PM   #16
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: block lift
Yea blocks in the front is just plain not safe. I would never do it either. Blocks are meant for the rear and add a leafs or arched springs for the front.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-13-2008, 06:14 PM   #17
vtblazer
vtblazer's Avatar
Re: block lift
Maybe I missed it but why not just buy an all spring lift?
If it's due to cost, you've got until the new year to save some cash...right?
Seams like to best choice IMO, no more harse ride and no more blocks to chuck.
Win/win for you.
vtblazer is offline   Reply With Quote
Old 11-13-2008, 07:15 PM   #18
dammitmitchell
the pollock
Re: block lift
the leafs were new when i bought it... buddy abouthg them a few months prior..
just gonna block the back the fronts okay.. would really like mreo articulation while mudding... so it's not so harsh when hit dry ruts or drive a trail..
what would be awsome is if my wife would get in my truck more often she asked me to put on steps for her (wuss) and she never rides in it ugggghhh..
Army vet 02-08
