Old 05-11-2002, 11:07 AM   #1
shortbed70
shortbed70's Avatar
Post Bedside swap ?
Will the bedside (swb) from a 67-68 fit on my 70. I know I will have to cut the hole for the marker light but I need to know if it will work. How hard is it to take off just the bed side?
1970 shortbed(project)
350/350 dropped 4/6 21/2" flowmasters. Dropping bigblock idea and building a stout smallblock...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-11-2002, 12:31 PM   #2
Southpa
Southpa's Avatar
Post
I swapped a 67 bedside onto my 70 (longfleet). I'm assuming there is no difference between swb and lwb, just the length. There might be differences between wood and steel decks tho. Mine was wood.
Remove the tailgate.
You have to unbolt all the hold-down (to the deck) carriage bolts along the edges. Might be easier to just turn them the other way so they snap off. Remove the bolts along the front holding the bedside to the forward bulkhead.
And you have to reach up inside the rear pillar and remove three bolts. There is also the stiffening rod about midway holding the front of the wheel arch to the frame.
And you also have to grind 2 welds (one vertical, one horizontal) at the back corner.
The whole bedside can be removed this way including the wheel tub. You also have the option of leaving the wheel tub, meaning you have to reach up and undo the bolts holding the tub to the bedside.
The rest is wrestling it off. Heres a few pics, sorry not a lot of detail...
http://communities.msn.com/Alsplac/b...nw?albumlist=2
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 05-11-2002, 05:20 PM   #3
shortbed70
shortbed70's Avatar
Smile
Thanks I was begining to wonder if anyone was going to help me. Now comes the fun part. Thanks for the info.
Troy
Big Red Dog build
