Old 11-03-2008, 01:41 AM   #1
custom63
custom63's Avatar
63 panhard bar
Hi all,
Im a long time reader of the site but this is my first post....so here I go. In the process of working up a 63 short fleet. I just got ahold of some nice donor parts from a 80 1/2 ton in which I got the whole front end for a complete brake and steering upgrade. Anyways, I am planning on bring the rear of the truck down 6in. using some of ECE lowered springs etc. However they are telling my that I can not go that low with my 63 cuz of the parhard bar set up. I guess the 65-72's are different. What gives? I understand the geometry problem with lowering. But they are saying that there super adjustable panhard bar still will not work with my 64. Can anyone point out and/or post some pics of the differences in these years for where the bar hooks to the frame and axle?
Thanks for helpin the new guy out!
custom63 is offline   Reply With Quote
Old 11-03-2008, 01:48 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: 63 panhard bar
Interesting. Both ECE and CCP list them for 65+. CCP does list an adjustable bar for 63-64 though link
Frizzle Fry is offline   Reply With Quote
Old 11-03-2008, 02:00 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 63 panhard bar
Could it be the placement of the panhard bar's "frame mount"? I'm not sure what else would be different. I think I would bolt the Super Track Bar to ECE's trailing arm bracket and move the frame mount. Just a guess,...
Keith
Convert to disc brakes.
Old 11-03-2008, 02:39 AM   #4
custom63
custom63's Avatar
Re: 63 panhard bar
lolife99, I have been going down your idea path as well. I just dont have a 65 and up to compare my 63 to in order to figure out where the big difference is on frame mount placement. But like you said I could just get the super trac bar kit, lower everything down to ride height, hook it up to the trailing arm side center everything and then find my placement to where I could "remount" on the frame. That could work right?
Old 11-03-2008, 03:01 AM   #5
lolife99
lolife99's Avatar
Re: 63 panhard bar
I think so. Not everything can be made "bolt on". But no reason why it wouldn't be possible. Keep us posted.
Keith
Old 11-03-2008, 10:14 AM   #6
bigwavy
bigwavy's Avatar
Re: 63 panhard bar
It's been a while but lets see....I believe the 64 rear has a different location at the axel for the panhard bar. There is a bracket welded to the right side tube rather than a boss on the pumpkin. It may be the same as the 63. Having said that, you may have to buy an adjustable panhard bar and fab your own mounting points. Thats what I did. Hope that helps. Doug
bigwavy is offline   Reply With Quote
Old 11-03-2008, 06:51 PM   #7
lolife99
lolife99's Avatar
Re: 63 panhard bar
If that's true,... then it won't matter since ECE's Super Track Bar attaches to the right side trailing arm.
Keith
Old 11-03-2008, 07:03 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
Re: 63 panhard bar
The frame mount for the panhard bar is different on the 63-64. As previously mentioned, you will need to modify/facricate/or replace the frame mount with a later-model one. The axle mount for the super-trac bar will bolt right up.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-03-2008, 07:21 PM   #9
Moose67
Moose67's Avatar
Re: 63 panhard bar
Here is a picture of the rearend in my 67. It is from a 63 or 64. My panhard bar from ECE is way short of reaching the frame mount.
Moose67 is offline   Reply With Quote
Old 11-03-2008, 08:19 PM   #10
lolife99
lolife99's Avatar
Re: 63 panhard bar
Here's where ECE's Super Track Bar attaches.
Keith
