11-03-2008, 10:40 AM | #1 |
700R4 behind a 250 I6 - TV cable hook-up
I am planning on swapping my 3 speed manual to a 700R4. I bought a 700R4 that has 100k miles and is still good but I am going to have it gone through. I also got the driveline w/yoke, tranny cooling lines, converter, TV cable, torq converter and the starter. I know I am going to by a cross member from some overdrivebowtie website but I didn't see the tv bracetry. Has anyone on here done this swap or seen any brackety for this or linkages/cables to make this conversion? I know the TV cable is very important.
11-03-2008, 01:21 PM | #2 |
Re: 700R4 behind a 250 I6 - TV cable hook-up
This is all I have seen for the other Rochester Carbs. Only 2 BBLs. May have to buy a kit and do a little Fab work?
http://www.bowtieoverdrives.com/cata...php?ITEMID=407 |
11-04-2008, 02:32 AM | #3 |
A stock auto crossmember will work fine, just needs to be moved back a little. I would call bowtie overdrives and get there opinion on what tv bracket you need.
Jay |
12-15-2008, 01:09 AM | #4 |
Grancuda, I hope you have better luck than I have. I bet they have something for you. I put a clifford 4bbl intake and Edl carb I haven't found anything that will work so I'm swapping to a TH350.
68 C10 2WD 250 6cyl Clifford 4bl, Edl Carb, Headers, work in progress |
12-15-2008, 01:29 AM | #5 |
You might have to fab up a bracket. Here's some info of the specifications:
http://www.purplesagetradingpost.com...o/700R4p1.html Good luck, should be a nice combo! Jay |
12-15-2008, 01:52 AM | #6 |
Out of the carpool lane.
Frank (pickmup) has done this conversion and might offer some insight.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
12-15-2008, 11:15 AM | #7 |
IMO, I would take an existing cable bracket and modify it before I wouldgo to the extreme of down grading to a TH350...
12-15-2008, 11:15 AM | #8 |
IMO, I would take an existing cable bracket and modify it before I would go to the extreme of down grading to a TH350...
12-15-2008, 11:49 AM | #9 |
I have seen trucks at the bone yard that have had 250/700r4's in them. The TV cable ran over the valve cover,so did the accelerator cable.(integral head.)
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
12-15-2008, 12:09 PM | #10 |
Moderator
12-15-2008, 12:10 PM | #11 |
Moderator
www.bowtieoverdrives has some great info, and I have heard great service, Give them a call.
