Old 11-03-2008, 01:29 PM   #1
Heavy Evy
born to lose
Heavy Evy's Avatar
Gas gauge problem HELP!!!!
Im pretty sure there's another thread about this but im to lazy to search for it at the moment. So my gas gauge is not working I have checked the gauge with a test light everything tested ok so I moved on, I took the sending unit out to find the float had a hole and would fill with gas and sink to the bottom of the tank. I cleaned the float and fixed it with a soldering iron it worked for a day then the gauge just read empty again so I pulled the sending unit out again thinking the float had broke again but it was fine. I ordered a new sending unit from lmc and put that in thiking it would fix the problem again it worked for about 2 days then the gauge went back to empty. I have no idea what the problem is with the stupid gauge please help me!!!!!!
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 11-03-2008, 01:59 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Gas gauge problem HELP!!!!
Sounds like a grounding problem?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-03-2008, 02:02 PM   #3
jorgensensc
jorgensensc's Avatar
When you ordered the new sending unit, did you use your known good float again, or did you use the float they sent with the unit. I have had nothing but bad luck with newer floats getting holes in them Now I solder and test them for a few days before I even install them You could have a bad float... again. There are other possibilities, but I would check the float again.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-03-2008, 11:38 PM   #4
69DISASTER
I had a similar problem with my 69 it was the wire going to the sending unit. Broken under rocker panel. Replaced entire wire and it works fine now.
69DISASTER is offline   Reply With Quote
Old 11-04-2008, 12:08 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Agreed...I would check the wire.
leddzepp is offline   Reply With Quote
