Old 11-03-2008, 02:09 PM   #1
wv panel
trailing arms question
I'm planning on replacing the trailing arms on my 64 C 10. Does anyone know the size of the U bolts located at the rear othe arms? Where is the best place to purchase new, bushings,bolts, etc. ? Thanks
wv panel is offline   Reply With Quote
Old 11-03-2008, 04:03 PM   #2
custom63
custom63's Avatar
Re: trailing arms question
What are you replacing the trailing arms with? I ask cuz Early Classic Enterprises (ECE) sells after market beefed up rear trailing arm replacment kits that come with everything you need. Check them out see what ya think. They also just sell replacement bushings too.
http://www.earlyclassic.com/home.aspx
custom63 is offline   Reply With Quote
Old 11-03-2008, 06:16 PM   #3
kizer
Its Deja Vu time again
kizer's Avatar
Save them or take good measurements. I ended up buying a pair from Lmctruck.com because
Napa didn't carry them
Autozone didn't carry them
Schucks didn't carry them
They all told me the samething after I cut them off. Oh if you bring in a bolt we can take some measurements. Well they where in the trash since I was cutting things off to strip and paint.
Bushings I bought mine from classicparts.com because well LMC wanted more than I wanted to spend.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 11-03-2008, 08:46 PM   #4
suicide 63
I found mine at a Fastenal Store for almost 4 dollars for the pair.I believe they are 3/4inch and about 8 in long.
suicide 63 is offline   Reply With Quote
Old 11-03-2008, 11:55 PM   #5
SCOTI
SCOTI's Avatar
I had them made @ a local spring shop. I brought in a stock u-bolt & told him I needed it 2" longer on each end (2" lowering blocks). $30 (including new crush nuts & washers); it took the guy about 5 -- 6mins & I was ready to go.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-04-2008, 12:50 AM   #6
Rollie396
someday it will be done!
Rollie396's Avatar
What Scoti said,to a tee.
When the fella came back so soon,I figured he had a question....nope,done.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 11-04-2008, 05:37 PM   #7
born loser
This might help:
NAPA U-BOLT SIZE LIST
“ROUND” U-Bolts for round axle tubes
NAPA PART NUMBER THREAD Ø / AXLE TUBE Ø / LEG LENGTH (* SEE NOTE BELOW)
650-4082 3/8*2.0*4.0
650-4079 7/16*2.0*6.0
650-4012 7/16*2.50*6.5
650-4023 7/16*2.75*6.75
650-4026 7/16*2.81*8.0
650-4075 7/16*3.0*7.5
650-4022 7/16*3.12*6.75
650-4076 1/2*2.5*8.25
650-4003 1/2*2.88*7.0
650-4077 1/2*3.0*11.75
650-4028 1/2*3.0*8.0
650-4001 1/2*3.13*6.50
650-4014 1/2*3.25*9.0
650-4002 1/2*3.50*7.50
650-4025 1/2*3.5*8.0
650-4053 9/16*3.0*7.25
650-4078 9/16*3.25*8.0
650-4036 9/16*3.37*7.0
650-4041 9/16*3.37*8.0
650-4034 9/16*3.37*10.0
650-4080 9/16*3.75*8.0
650-4081 9/16*3.75*12.75
650-4044 5/8*3.0*7.5
650-4050 5/8*3.01*8.63
650-4051 5/8*3.0*9.63
650-4052 5/8*3.0*11.63
650-4045 5/8*3.25*8.50
650-4042 5/8*3.25*9.0
650-4038 5/8*3.25*13.0
650-4049 5/8*3.25*8.50
650-4053 5/8*3.50*9.50
650-4054 5/8*3.50*10.50
650-4055 5/8*3.50*11.50
650-4056 5/8*3.63*7.50
650-4057 5/8*3.63*8.50
650-4058 5/8*3.63*9.50
650-4059 5/8*3.63*10.50
650-4060 5/8*3.63*11.50
650-4037 5/8*3.75*8.50
650-4035 5/8*3.75*10.0
650-1050 3/4*3.0*18.0
650-1052 7/8*3.0*14.0
650-1054 7/8*3.5*14.0
650-1055 7/8*5*14.0
650-1056 7/8*3*18.0
650-1057 7/8*3.5*18.0
*NOTE on Leg Length:
Leg length is measured from the end of the threaded leg to the INSIDE bottom of the U
born loser is offline   Reply With Quote
Old 11-04-2008, 06:05 PM   #8
kizer
kizer's Avatar
I bought these like I mentioned up above and could try and look at the tag that I might have laying around in the garage since it does have the dimensions on it.
Old 11-04-2008, 09:38 PM   #9
LILRED66
LILRED66's Avatar
Good information guys...thanks for sharing.
LILRED66 is offline   Reply With Quote
Old 11-04-2008, 10:53 PM   #10
joe231
joe231's Avatar
nice post loser!!
CHEVY ONLY
Old 11-04-2008, 10:57 PM   #11
kizer
kizer's Avatar
Ok I found the label off the U-bolts.
Exactly what does it mean. Well that is for somebody else to pipe up and say.
Keep in mind that there where 2 washers and 2 nuts connected to this as a package that I bought. The bolts for sure are not 3.5 inches long.
Does that mean 3/4 thick with a 3 1/2 gap between the bolts at 8 1/2 long? If so that sounds about right to me
Old 11-06-2008, 03:25 PM   #12
66trkbldr
LIGHTMUP,BURNMDWN!
66trkbldr's Avatar
Hey !!!!!!!!! bought a set of rear trailing arms from ebay ! they came from a nascar truck series team ! used of course but thet were only 75.00 for the pair ,same length and they evan fixed my pinion angle with the drop blocks and notch!!!!!!!!!! save the $ of buying repops ! theres normally a pair a week , " truck arm" they look bad a$$ !
64 LWB Chevy " EL DEVILLE"
61 Caddy ambulance
56 Coupe deville
64 Coupe deville
29 Ford roadster
66trkbldr is offline   Reply With Quote
Old 11-06-2008, 03:29 PM   #13
SCOTI
SCOTI's Avatar
Put up the e-bay linky.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-06-2008, 03:59 PM   #14
kizer
kizer's Avatar
Yeah at least so we can see what they look like. I searched and didn't come up with anything.
Old 11-06-2008, 05:10 PM   #15
joe231
joe231's Avatar
CHEVY ONLY
Old 08-21-2010, 09:05 AM   #16
astrochimp
Does anyone have a online source for these?
Well 2" longer ones, so I can add lowering blocks.
David
astrochimp is offline   Reply With Quote
Old 08-21-2010, 10:22 AM   #17
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
David
Nothing I know of online
However, most spring shops will make them however you want.
I had a set made up while I waited; price was reasonable too.
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 08-27-2010, 12:13 PM   #18
63sbssbbw
UCA63
63sbssbbw's Avatar
for Kizer
3/4 = rod dia.
3 1/2 = width ( at inside of legs)
8 1/2 = height ( from inside of arc to end of leg)
Thread should be 3/4-16 fine.
with matching high nuts(which you have) but i don't see the split lock washers that you'll need
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 08-27-2010, 01:02 PM   #19
CVA59
Mine came in yesterday from http://www.classicparts.com/. They were 12.00 i piece i think. They fit perfectly. I would say that is the way to go.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 08-27-2010, 01:22 PM   #20
SCOTI
SCOTI's Avatar
Were yours for leaf or coil suspension? Leaf u-bolts are typically cheaper because they're smaller.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-28-2010, 12:22 AM   #21
Captainfab
60-66 Nut
Split lock wshers aren't typically used under U-bolt nuts. Heavy SAE flat washers are what I normally receive with new U-bolts. When torqued properly, they won't come loose.
Originally Posted by 63sbssbbw View Post
for Kizer
3/4 = rod dia.
T
Old 08-28-2010, 06:05 AM   #22
63sbssbbw
UCA63
63sbssbbw's Avatar
Okay,thanks cpt fab
The ones I just took out must have been cracked(and in more than 1 place)
I just assumed it was a lock washer.
I should have consulted my assy manual before I opened my yap
Sorry 'bout that Kizer
T
member#7816
'61 GMC in progress
Old 08-28-2010, 11:45 PM   #23
Captainfab
60-66 Nut
No worries here, I just wanted to state what I know. And thanks for posting the dimensions of the U-bolts.
Okay,thanks cpt fab
T
Old 09-11-2010, 08:22 PM   #24
astrochimp
I got a set from my local lumber yard, they had to order them in, they didn't stock any that big. 3/4"- 3.5"- 12"
They are from " Rods Indiana Inc", and 12" long, but threaded enough you could use them for stock (cut off excess).
