11-03-2008, 04:57 PM | #1 |
Undercoating prep
What should I do to the bottom of my floorboard before I undercoat it?
I've done some work on it and its' bare steel in many places. The original part of the floor is already undercoated, so I was just going to undercoat the new patch panels too and make it all match under there. Do I just spray the undercoating over the bare steel? ...or etch prime, then coat? ...or etch prime, prime, then coat? ...or etch prime, prime, paint, and then coat? ...or what? |
11-03-2008, 08:23 PM | #2 |
Re: Undercoating prep
i would etch prime seam seal then undercoat
11-03-2008, 08:24 PM | #3 |
I epoxie prime, paint and coat with under coating.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
11-03-2008, 08:59 PM | #4 |
epoxy primer then coat. Etching is kind of a waste these days...it's expensive stuff.
11-03-2008, 10:48 PM | #5 |
PITbut
I just did this today. I had bare steel. I epoxied it in case i missed anything with the undercoat. Then i sprayed AL's liner on the bottom. When sprayed right it looks JUST like linex.... Awesome stuff.. I will tell you in 48 hours how well it holds up....
If you go to my build thread i will have some updates soon with pics.. I put it on my core support also... |
