Old 11-03-2008, 09:47 PM   #1
71Farmtruck
Junk Junkie
71Farmtruck's Avatar
Interchangeable brake booster?
I wanted to know if you can swap the two different common types of brake boosters on 81-82 trucks, I have the shorter width, larger diameter booster on my truck, which has gone bad, and a good larger width smaller diameter booster on hand. Anybody know of any differences that would make them non-interchangeable?
Mike
71 Chevrolet C-10 Short Bed Stepside
81 GMC 1500 Sierra Classic Long Bed
71Farmtruck is offline   Reply With Quote
Old 11-04-2008, 09:13 AM   #2
71Farmtruck
Junk Junkie
Re: Interchangeable brake booster?
Bump again, anyone have any input on the different boosters?
Mike
Old 11-04-2008, 05:28 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The 2 types are HD (dual diapram) and non HD. If I remember correctly the rod is different lengths.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-05-2008, 12:46 AM   #4
71Farmtruck
Junk Junkie
Well, I was wrong on the diameter, they are both the same. The good other one is thicker, I'll bet its the dual diaphragm. It came off a suburban. I lined them up side by side and there was no noticeable difference in rod length in this instance. I tore it all down and removed the old one, I have the new one loosely on there, we'll see how it all runs when everything is tightened up.
Mike
Old 11-05-2008, 05:01 PM   #5
Captkaos
Captkaos's Avatar
All the burbs I have ever worked on or took apart had HD boosters, did you swap rods from one to the other or use what was on the booster?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-07-2008, 10:23 AM   #6
71Farmtruck
Junk Junkie
It swapped over fine, I used the burb's rod, bolted in like it belonged there. I am still unable to make this turd idle, keeps dying out.
Mike
Old 11-07-2008, 03:29 PM   #7
71Farmtruck
Junk Junkie
Figured it out, it is flooding.
Mike
Old 11-07-2008, 03:51 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
That's weird. One time I had a truck with the light duty boost and put the HD booster on it. Used the same rod and it worked just fine.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-07-2008, 10:42 PM   #9
71Farmtruck
Junk Junkie
That was the case with mine, bolted up fine.
Mike
