Sierra Grande Club
Inline tube trans lines/ bent wrong?
I ordered some inline tube trans cooler lines and tried to install them. They don't look quite right to me.
I called them and mentioned about the shipping bend. Cameron said "we don't put shipping bends on transmission lines". They sent them to me like that. So I straightened the bend out per their instructions and it seems close. the lower line was shipped just like it is, and it seem short! I have the upper line hooked to the top of the hole on the transmission, and the lower line to the lower hole. Is this correct? anyone else have problems with inline tube? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: Inline tube trans lines/ bent wrong?
I did. I ordered a complete braided stainless steel brake hose kit. The back one fit just fine, but the front ones did not come with the correct fittings or a banjo bolt. I called them and they just told me, Well just send it back then. They did not even ask what was wrong or anything. I personally will not order from them again. I just bought some stock rubber ones instead. sucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
Sierra Grande Club
bump..
WTB this ad
I bought a prebent line to run from the fuel pump to the carb. It's fit was dead on.
#5 | |
Sierra Grande Club
![]() BTW - when I seen that you replied I thought you were going to tell me to get a better camera! ![]() s/t
I purchased my SS tranny lines from Inline Tube and they were perfect.
I bought stainless fuel lines from them for a swb 71 with a 6cyl. First they sent v8 lines then they asked for pics of my 6cyl line. They said mine wasn't like their forms. They sent me what they had. It is completely different but should end up with the end where it should be for the pump. I checked a 68 parts truck I have and the line is identical to the one on my 71. I emailed them to tell them their form was wrong and never heard back. As they seem to be THE supplier to resto shops, I'm sure I'll end up with more of their product later, but I hope I have better luck. If I just wanted it to be close, I'd have made them myself.
I think you can get better than "close" bending them yourself. just buy a nice bender and flare tool.
I ordered a couple different diameter SS lines from Inline, and I'm getting really good results doing it myself. Besides, you will have the option of putting things where you want them...
RN U OVR |
![]() Join Date: Sep 2005
i've never had problem witht here stuff
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Sierra Grande Club
I called today and talked to Mark. They want me to send some pictures with them in the truck and lying on the ground. So far they are helping and have been pretty cool.
I’ll keep everyone posted. s/t
Active Member
Those bends do not look nice or correct - they should be much crisper and cleaner
If you do not get any good response call the right stuff http://www.rightstuffdetailing.com/ They can hook you up with a set of lines
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
I have Inline pieces on my 4x4 and while they are pretty nice,I used the right stuff trans lines on my bb truck and they fit flawlessly and look just like the originals did.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#13 |
Sierra Grande Club
They want pictures so these are what I'm sending.....
s/t
#14 |
Where can a guy get the clip that attaches to the oil pan? I don't have that and the lines really need it.
Is it available aftermarket? |
#15 |
Sierra Grande Club
And the rest...
#16 | |
Sierra Grande Club
Mine was on the truck when I got it. But I think Wes sells them. s/t
#17 |
![]() Join Date: Jul 2004
The top line is the return and the bottom line is the pressure IIRC. The hot fluid should enter the rad at the top and exit the cooler part of the rad at the bottom. I think your lines are reversed at the trans. Is your engine mounted in the V8 location or the inline 6 position ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#18 | |
Sierra Grande Club
The lines were only finger tight. and I checked into switching them but don't think it will help.... So which one should go into the lower fitting on the transmission? s/t
#19 |
What I`ve bought from Inline has been perfect.They were very strick on getting proper information and you need to be sure you are at factory specs because that`s what they go by.I needed something custom and they were reluctant.I got them to do it with my specs and it was mine right or wrong.It was perfect.I needed a specified length on hoses with specific fittings and some standard stuff that all fit together.It all went right together.
I know lines can be frustrating.I hope you get it worked out.I think they are a good company that will work with you.Let us know the results.
#20 |
Sierra Grande Club
*UPDATE*
I sent them pictures of my problem and it seems they are having internet/email problems. Mark on the 5th informed me about this, and said he would be getting back with me. When I called on the 6th Mark said he was discussing the problem with someone (engineering?) I called Friday morning and talked to Cameron again. He said emil the pictures to him and hell take care of me, and I did just that. I called later that afternoon and he said they were having problems with the internet/email. He said he would bet back to me later, I told him I would be leaving work soon and offered him my phone number. He quickly said that it probably would be Monday before gets back to me. But he said he would take care of me. So another weekend without parts....... s/t
#21 |
Sierra Grande Club
I got a call from Inline tube today and they said those are definitely the correct lines.
![]() ![]() I asked for an over all length so I could double check to their measurements but that me a blank stare that I could see over the phone. ![]() I finally decided to called Wes at Classic Heartbeat, to tell him what was going on. (I ordered them through him) I sent him the same pictures and he said they don't look correct either, and he would take care of it. Basically they told him they are correct, and if they send new ones they will be the same. So Wes said he would have Therightstuff send there lines to me and we can compare. ![]() I sure like dealing with Wes, and this is just another good reason! PS if anyone can take a measurement of the trans lines, I would love to check it against mine. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 11-10-2008 at 09:44 PM. |
#22 | |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
