I like turtles...
how low did u go?
hey guys, i found a new project that hopefully will be buying sometime this week, its a 69 swb. so ive got some questions
how low did u go on the zing of the frame? how many inches for the bodydrop? did u have to modify the crossmember? how did u modify the tranny mount? any help will be great before i start tearing into it ![]()
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock ![]() Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
Happy to be here
![]() Join Date: Mar 2000
Re: how low did u go?
You really don't specify what you want to accomplish. The whole point of Z'ing a frame is to avoid a body drop. Do you want a body drop, or a Z?
I used airbags/drop spindles/blocks to lower my truck.
Here are a few things I ran into. 1) My front tires hit the inner wheel wells. So that is probably going to be one of your first limitations. My tires and track width are a little wider than than others, but either way the inner wheel wells will get in the way. You can get rid of them, modify them, or make new ones to get over this hump. 2) I'm running a 5.3L with a 4L60E. For header clearance and tranny clearance, I modified the tranny crossmember to raise the tail of the tranny up. With the bags aired out the drive shaft was hitting the back of the cab. I did ended up making a new crossmember and solved those issues, but something I didn't consider (oh, btw I'm using a 1 piece drive shaft). With all of that the frame is about 6" off the ground with 29" tall tires. |
depends on tire size, i Z'd my old frame 3" and laidout on a 28 inch tire(20" wheel) with air bags, 2.5" drop spindles and art control arms... how many inches for the bodydrop? only one inch is needed to lay rockers, have to remove the pinch weld first.. did u have to modify the crossmember? not with a frame Z... how did u modify the tranny mount? yes, must be moved up the same amount that you Z the frame...
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 11-05-2008 at 11:28 AM. |
#5 | |
3DrDwn--the 'burb not the band
WOW that was just supposed to be a few pointers. guess I got a lil longwinded. hope it was helpful at least. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
I like turtles...
so if i z the frame i dont have to bodydrop it? will it still lay rockers?
and thanks RunninLo, that seems to be the way ill go.
no you will still be about 1" away from rockers
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
I like turtles...
but cab that be atcheved by modifying the rubber on the cab mounts?
that or moving the body mount down... remember if you bodydrop it you need to add another inch to the trans tunnel, witch i forgot to mention also needs to be raised with a frame Z...
