Old 11-04-2008, 10:51 AM   #1
67chevemall
67chevemall's Avatar
Hub Centric ??
So the rim I want from Summit is Hub Centric...?What does this mean and do they fit our trucks?
The guy at Summit doesn't know the center bore diameter.
He gave me the number for Pro Comp but can't seen to get a human there yet......
I think it is like bimmer rims where they sit right tight on the hub and center it....?>
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-04-2008, 11:51 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Hub Centric ??
Yes, hub centric is the term used where the hub locates the wheel.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-04-2008, 12:55 PM   #3
67chevemall
Re: Hub Centric ??
Well I got a hold of em
and glad I did the center is too small on hub centric. Made for newer trucks. Got the right part number I need but summit doesn't sell em...DOE
Old 11-04-2008, 12:57 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Hub Centric ??
Best bet on our trucks is to find wheels that are lug-centric. It eliminates the "worry of being close".
Member Nr. 2770
Old 11-04-2008, 05:07 PM   #5
67chevemall
Re: Hub Centric ??
Well I got it straight Same wheel different part number for lug centric.
That was alot of work to get wheels and tires wow
Hope they fit.....
Old 11-04-2008, 05:25 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Hub Centric ??
ours use hub centric wheels too, just not the same size hub.
It's always a good idea to get the proper fitting wheel... esp if you haul any weight. Those lugs just aren't designed to hold the weight of the truck.
Old 11-04-2008, 09:42 PM   #7
cparman
sharp as a marble
Re: Hub Centric ??
two terms:
Lug centric, most aftermarket wheels are made this way. The wheel centers on the lug studs.
Hub centric, the wheel centers on the center hub.
If a wheel is hub centric ( all OE wheels are ) when you loosen the lug nuts, the wheel will typically tilt, or fall off of the centering hub.
Lug centric wheels, when the lug nuts are loosened will just drop a bit and stay in place.
The prefered choice is the OE way. HUB CENTRIC. A truer centering of the wheel to the hub, and a better ride, and load capabilities. Some, but not all wheel manufacturers will offer centering rings for their lug centric wheels, making them hub centric
cparman is offline   Reply With Quote
