11-04-2008, 12:18 PM | #1 |
Gettin By on Gettin By
marker lights: always on or blinker??
I'm to the point where i'm figuring out my side marker light wiring on my 69. The front i just have the marker lenses, no wiring, and on the rear its been hacked up pretty bad.
My questions is, do the front markers blink with the blinkers only? and what about the rear?? Seems from what wiring i have left, they come on with the lights, but don't blink or anything else. Whats going on here??
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
11-04-2008, 12:22 PM | #2 |
Next project: 1970 K10
Re: marker lights: always on or blinker??
They are usually just tapped in to the park lights (brown wire, I think). No blinky, just steady burn with the running lights or head lights.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
11-04-2008, 12:31 PM | #3 |
Hollister Road Co.
My 72 front side lights go on with the parking lights and blink with the signals. The rears do not blink.
11-04-2008, 12:42 PM | #4 |
What do the front blub sockets look like?? i assume they are totally different then rear.
11-04-2008, 12:52 PM | #5 |
They are identical on every one I have messed with, front and rear. They use a 194 push-in type bulb like the dash light bulbs.
Originally, the fronts are wired to brown and run to the light switch
11-04-2008, 01:19 PM | #6 |
On my old GMC, they blinked with the turn signal, and came on with the parking lights. that's what i plan on doing with my chevy too.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
11-04-2008, 01:26 PM | #7 |
Interesting. I would like to know how they wired them so I could add that as an option to my wiring diagrams. All the ones I have show only a park light routing.
11-04-2008, 01:57 PM | #8 |
Anyone have a picture of what the marker lamps sockets look like for the blinking and on. Do they fit into the chrome ringed markers??
11-04-2008, 02:46 PM | #9 |
The rear marker lights burn steady with the parking lights on. The front markers will come on with the parking lights as well. The fronts flash with the turn signals when the parking lights are off and they flash opposite the turn signals when the parking lights are on. They work that way because the grounds reverse depending on if the parking lights are on or not.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
11-04-2008, 02:47 PM | #10 |
11-04-2008, 03:16 PM | #11 |
AHHH.. well that makes sense.
All 4 are on with the parking lights, and the front blink off. The front parking lights are kind of odd like that too arn't they?? They only come on when the parking lights only are on, and turn off when your head lights are on, but blink?? Thanks mvfd.
11-04-2008, 03:36 PM | #12 |
Was this an option? None of my trucks flash the front marker lights. Of those that I have had that had the markers wired from the factory (some didn't) they were all wired like this:
11-04-2008, 04:25 PM | #13 |
Super easy to wire. Leave the wire that turns on the markers (usually brown) Then remove the ground wire and tie it in to the signal wire. (light blue and dark blue)
11-04-2008, 04:30 PM | #14 |
Copy that, thanks!!!
11-04-2008, 04:53 PM | #15 |
Right on. Great info. I guess you can do the same for the rear, just tie it into the green and yellow??
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" Last edited by jayharrell; 11-04-2008 at 04:53 PM. |
11-04-2008, 05:29 PM | #16 |
its all about the +6 inches
If you do that for the rear, they will turn off every time you hit the brakes.
I have found no rhyme nor reason as to why some blinked, and others did not. This is however, true, that some did, and others did not. I have had 2 from the same plant side by side, same year, neither hacked, side by side... only seperated by a few thousand on the assembly number, one blinked, one did not. |
11-04-2008, 05:33 PM | #17 |
Maybe a guy on one shift thought it would be cool if they blinked, and a guy on the next shift just wanted to hurry and get done so he could get to the bar on time?
11-04-2008, 08:10 PM | #18 |
11-04-2008, 09:31 PM | #19 | |
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-14-2014, 02:27 AM | #20 |
Good info. Anyone figure how to get the rear markers to blink??
04-14-2014, 06:55 AM | #21 |
This is an old post, but the OP says his "69".. I have 2 69s and niether had side markers that were wired to light, is this an option?
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
04-14-2014, 11:39 AM | #22 |
My 69 (Dec., 1968, production) did not come from GM with lighted markers, only reflectors (see pic below). There was no option for lighted markers. I THINK I read on here that reflectors OR lights were required starting in 1968 and that lights and reflectors were required starting Jan. 1, 1970. I can't vouch that this is correct though. I do know that the deluxe style markers were introduced during the 1969 model year and believe that they were all lighted.
04-14-2014, 12:33 PM | #23 |
Far as I know lighted side markers were an option in '69. If not they have only reflectors.
In any event, long thread on this subject here: http://67-72chevytrucks.com/vboard/s...d.php?t=503138
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
04-17-2014, 10:54 AM | #24 | |
Roadtrip!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-17-2014, 11:34 AM | #25 |
I'll be darned. Glad I said I "believe that they were all lighted". My 69 CST came new with the standard reflectors. I called and asked GM why my CST didn't have the deluxe markers and was told the deluxe markers came out a couple weeks after my truck was built in Dec., 68. I assumed they were all lighted. Never too old to learn. It also did not have a headliner which had become part of the CST trim.
