Old 11-04-2008, 04:57 PM   #1
JoeKan
JoeKan's Avatar
Spedo cable
Can someone tell me how to change out the spedo cable? Do I need to take it completely out/off? I've tried to take it off from underneath, but it's pretty tight, that's why I'm not sure if it is to come off or not.
Thanks,
Joe
Oops. I just noticed that was the throttle cable. Maybe someone can tell me where the spedo cable is??
JoeKan is offline   Reply With Quote
Old 11-04-2008, 09:51 PM   #2
JoeKan
JoeKan's Avatar
Re: Spedo cable
Anyone??????????
Old 11-04-2008, 09:57 PM   #3
LILRED66
LILRED66's Avatar
Re: Spedo cable
The speedo cable runs through the floor board/firewall and into the back of the dash assembly. It screws into the back of the speedometer/odometer and must be removed at this location, as well as the transmission, in order to replace.
You may save yourself some frustration by removing the engine dash gauge assembly.
Good luck with your project and I hope this information is helpful.
LILRED66 is offline   Reply With Quote
Old 11-05-2008, 02:42 PM   #4
JoeKan
JoeKan's Avatar
Re: Spedo cable
Thanks for the info. Does this mean I have to take out the trim piece around my dash and then pull the dash guages out towards me to get to the spedo cable?
Also, my gas guage doesn't work either. What would you suggest I do? The PO had a new gas tank installed and the wiring coming off the tank looks to be in good condition. He said it was working until a few days before I came to pick it up, then it stopped working. I don't know??
Thanks again,
Joe
Old 11-05-2008, 03:34 PM   #5
502tripower
502tripower's Avatar
Re: Spedo cable
Thanks again,
Joe
If you remove the screws in the trim ring the entire insterment cluster can be removed as you said. Also I would check to see that your ground wire for the fuel sending unit has a good connection. Most likely this is the problem for the fuel gauge not working since the PO did replace the fuel tank. Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
