Finally found my gas leak today
Right after filling her up I decided to fold the seat forward and I saw the drip drip drip right at the sending unit to (vertical) gas line connection. Leak stopped after I started the truck. Shortly after turning off it started dripping again. I took it home and drained 5 gallons out of it and that stopped the leak. I've already tightened this connection. Is there an o-ring or compression farrel in there that is worn out....or should a little thread sealant do the job? Thanks, Bob
I'm a grateful Christian not perfect in any way, but always striving to become better with Christ's help. I'm grateful for what He did for me on that cross at Calvary. I hope there is a desire in your heart for the same: If you confess with your mouth that Jesus is Lord and believe in your heart that God raised him from the dead, you will be saved. Romans 10:9 |
Out of the carpool lane.
Re: Finally found my gas leak today
Yes, there's a big O ring at that connection and hopefully you're close to a good hardware store where you can find another one. I'm sure the major vendors have them as well however.
Oh, almost forgot- you might be able to get away with bending the tabs that hold the sending unit in place. That may be just enough downward force to stop the leak-for free!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 11-04-2008 at 09:02 PM. |
I have heard that soap works ? I have never tried it.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
i'd try cleaning both parts of the tubing connection with very fine steelwool they may have deposits on them preventig a good seal on the tubing connection
just dont weld it shut lol
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
#6 | |
blood type; Retumbo
possible a kerfagled flare on the line? remove for inspection. if this in fact the problem I would cut the line a few inches back and fab a new line. when I make new flares I dont completely finish the flare. I let the fitting do the last little bit. I would also not use hose for connecting the old with new. |
Aye! You might be right laddy!
70ChevyCST, I'd just start by wrapping the threads in teflon tape and trying that for starters. Actually, I'd just put a wrench on it first and tighten it. You never mentioned if you had done that already. ![]()
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#8 | |
Oh yes almost forgot....Gee thanks...I was thinking of getting my MIG out while
