Old 11-04-2008, 05:37 PM   #1
musiqlova
Squeaky Belts!!!
ARGGGH!
Help me y'all. One day my truck is sounding perfect and the next day I have noisy belts! I've replaced my AC belt and the noise is still there. Do belts just go bad overnight? Belt dressing just makes the noise worse.
Anyone has any ideas?
musiqlova is offline   Reply With Quote
Old 11-04-2008, 06:06 PM   #2
grinch4om
dang its hot
grinch4om's Avatar
Re: Squeaky Belts!!!
one of them isn't tight enough or a braket has come loose or bent making alignment not true
grinch4om is offline   Reply With Quote
Old 11-04-2008, 06:48 PM   #3
blu87
blu87's Avatar
To find out which belt if you don't know spray water on them one at a time. Then take some sand paper to the pulley and the belt...should take care of it.
Gene
blu87 is offline   Reply With Quote
Old 11-05-2008, 01:38 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I am guessing one is loose or a little bit out of alignment.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-05-2008, 04:05 PM   #5
musiqlova
Someone else locally told me about the water/sandpaper trick but i didn't believe it. I'll have to work on it this weekend because it is dark when i go to work and dark when i get home.
How will i know it's out of alignment?
I'll report back with my findings on Saturday morning.
Old 11-09-2008, 12:59 PM   #6
musiqlova
The darn alternator belt was frayed on one side. I replaced it with a new Dayco and no chirping so far. I did sand the pulleys while i had it off so maybe it was a combination of the new belt and the sanding.
