11-04-2008, 06:13 PM | #1 |
Help! Heater blower ground?
... what is the best way to ground the heater blower motor ground. I tried running a ground to the peg that holds the blower motor to the body but burned up the ground wire as soon as I hooked the battery negative terminal back up. Where do I place the ground? Also, what gauge wire should I use or any tips on the heater system in general.
11-04-2008, 07:44 PM | #2 |
Son of a gun
Re: Help! Heater blower ground?
If you are burning up the ground wire you ahve more problems than where to put the ground! The ground wire should run to the screw at the 1:00 position, holding the motor in...for an AC truck, I am not sure on a no AC truck.
Bill BEATERS ARE NEATER |
04-29-2013, 08:59 PM | #3 |
Anyone have more infor on the blower ground? Any picture? I'm reinstalling and don't remember the ground location.
Thanks Posted via Mobile Device |
04-29-2013, 10:45 PM | #4 | |
The Older Generation
LockDoc
05-04-2013, 03:05 PM | #5 |
Here ya go.
05-04-2013, 05:00 PM | #6 |
you may want to check the blower motor and make sure its still good...sounds like a short to me....should not burn up ground wire...
05-05-2013, 09:54 PM | #7 |
How can I test the blower motor to see ifit works, without hurting anything?
05-06-2013, 01:29 AM | #8 |
Just remove the truck wiring from the blower motor. run a ground lead directly from the battery to the ground wire and run a wire from the + side of the battery to the hot terminal on the blower motor. It should spin. If it works this way then you know it is a problem within the truck harness.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
05-06-2013, 11:17 AM | #9 | |
05-06-2013, 12:14 PM | #10 |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
