11-04-2008, 06:51 PM | #1 |
Easy Does It
Door stuck !!!
I was trying to adjust my door, with the striker plate, well I,ve adjusted it too far in and now the door will not open. I,ve tried everything I can think of including kicking it, but it will not open. Is there some wat to get the doors open if they get like this?? thanks
11-04-2008, 11:08 PM | #2 |
1961 crewcab
Re: Door stuck !!!
I would pull the handle from the inside, maybe get someone to help you, and then push with your feet from the inside, it must be jammed up.
If that dosent work ,pull the fender and unbolt the hinges, that will definatly loosen it up! |
11-04-2008, 11:44 PM | #3 |
Re: Door stuck !!!
nope, sorry
you will never be able to open that door again... time to act like you live in Hazard county j/k did you try lifting up on the door as to try to un-jam it? might have to get mean with it!
CHEVY ONLY Last edited by joe231; 11-04-2008 at 11:47 PM. |
11-05-2008, 02:31 PM | #4 |
Re: Door stuck !!!
Watching this thread with interest. My pass. door is stuck "ajar", won't open and won't close all the way. Didn't want to kick it because I don't want to break something (if it's not already broken). Spent about 6 man hours getting the screws out of the driver's door panel several years ago and sprayed the crap out of the pass. door panel screws with PB Blaster but still no joy with a hand impact driver.
66 Custom Camper 327/ 4 spd. Bone Stock, down to the split rims |
11-05-2008, 05:46 PM | #5 |
Re: Door stuck !!!
Thats funny Joethat use be my favorite show then they took it off.
