Old 11-04-2008, 07:07 PM   #1
Kycarguy
Help: Will wheels from a 1998 Chevy 2500 fit a 1977 1 ton 3500?
Hello. I have a 1977 1 ton 3500 Chevy ramp truck that has Aluminum wheels. One of my front wheels was stolen with a brand new tire. I found a set of wheels for a 1998 GMC/Chevy 2500, 8 lug x 6.5".They are 6" wide. I have looked all over and can't find out if these would fit.I know the 6" width is fine, the 8 lug x 6.5" should be fine. I guess the question would be the center hole size. Would these be different?
I have this ramp truck and a 74 El Camino SS-454 so I will be coming here now that I found out about this forum. Many thanks in advance.
ky car guy1 at yahoo dot com
Kycarguy is offline   Reply With Quote
Old 11-04-2008, 07:13 PM   #2
abebummy26
abebummy26's Avatar
Re: Help: Will wheels from a 1998 Chevy 2500 fit a 1977 1 ton 3500?
I'm not sure about the backspacing if it would work or not
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 11-04-2008, 07:24 PM   #3
78 Chevyrado
Other than backspacing, the lug spacing is the same for 3/4 and 1 tons from around 1967-present (8x6.5). I think the center holes are the same, but that may only be on SRW 1 tons. The backspacing should be a lot different on duallys because theres a big spacer on or built into the front brake rotor. If it's a SRW truck they swap over no problem.
78 Chevyrado is offline   Reply With Quote
Old 11-04-2008, 07:59 PM   #4
Kycarguy
I have studied the pictures. It looks these wheels have the same backspacing as my present 3 wheels. 4 minus the stolen wheel. I think the guy may be mistaken about these coming from a 3/4 ton 2500 and should be a 1 ton 3500. I can see the rust mark on 2 of the wheels where the steel ring would have been. He is 800 miles from me or else I would go see them in person to check. Thanks for all the information so far.
Old 11-04-2008, 09:36 PM   #5
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: Help: Will wheels from a 1998 Chevy 2500 fit a 1977 1 ton 3500?
I was just about to ask you that!
BTW 2 the board your gonna like it here!
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 11-06-2008, 10:49 AM   #6
Eyegore
What Hump?
Eyegore's Avatar
I have 2003 HD wheels on my 78 CS 3/4 ton, they fit just fine.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 11-10-2008, 01:46 AM   #7
Kycarguy
I ordered the wheels on Thursday and they should be here Tuesday. In the pictures he sent me they look like 1 ton dually wheels and that's what I am looking for. I will make a post once I receive them. Thanks everyone.
Old 11-14-2008, 02:53 PM   #8
Kycarguy
I received the wheels and they look like the ones I need for my 1 ton truck. I haven't put the one yet I need but pretty sure it is the one I need with the offset and 8 lug pattern.
I think the salvage yard I bought them from mis-marked the truck they came off of.
One of the wheels has a larger center hole then the others. I think this was made for a Ford truck since they need more clearance there then Chevy's, but the 8 lug pattern is the same.
Thanks.
