Old 11-04-2008, 09:51 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Im at my wits end here with door alignment.
Im really at my end here. This door is goign to be the damn DEATH of me...
I can NOT get it to align. The top upper left corner touches and the upper right where it curves down is sitting about 3/4 of an inch to low.
My questions are this.
Can that door frame be bent? Can i remove the spot welds at the bottom right corner of the post and pull the post up a bit and reweld it???
ANY tips to getting the door to align would be appreciated.. here is another pic... Also, the hinges were pretty bad so i replaced them. Nice and firm now.
lyrikz is offline   Reply With Quote
Old 11-04-2008, 10:02 PM   #2
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: Im at my wits end here with door alignment.
Just a thought... add a couple of washers under the upper door hinge where the door bolts too and try lifting the whole door a bit... You can also slide the upper part of the door out at the same time.
These things are tricky to align... I had to use a washer or two to get mine to align... also raising my hinges helped alot...even if it is a little bit.
You might be suprised what raising or lowering the hinges can do to alignment...
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-04-2008, 10:04 PM   #3
56fleetside
///RELAXED ATMOSPHERE
56fleetside's Avatar
Yes alot of times it takes cutting and welding to make doors and cabs line up. that looks to be your only alternative in this case.
Like a BOSS
56fleetside is offline   Reply With Quote
Old 11-04-2008, 10:48 PM   #4
71 super
71 super's Avatar
Couple of questions. Has the hinge on the top been rebuilt? If you lift on the rear of the door do you feel slack/loose? If yes to question 2 the hinge is your problem. The pins have only a nylon bushing to support them and these after 30+ years give up and cause all types of problems. Is the door GM or aftermarket? If aftermarket many of them do not fit the hole very well and require adjustments to the window frame to fit the hole correctly- i.e. removing spot welds and adjusting. Is the door original to the truck? Some doors just don't fit other trucks very well. Last one have the rockers been replaced? Were the door opening braced when the rockers were cut out? If not the opening could have shifted and caused the problems you are having. I hope that the problem is the hinge as it is a $6 fix and relatively easy.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-04-2008, 11:05 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
It looks to me like the truck might have been wrecked at one time. With the wide door gap at the bottom of the wing window and the gap at the back top corner I don't think you will be able to adjust it out.... I would say that the top of the a pillar is pushed back. How does the other side look?
LockDoc
Leon
Old 11-05-2008, 07:45 AM   #6
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Have you tried a different door? if you can strip and old door off a junker or something and have a look to see how it fits...as this might just be an out of shape door prob and not as big as a cab prob. If it's the same bad fit take the glass out of your door and cut and weld your door around the window frame to fit the opening rather than the other way round. Won't be to much of a change in shape to affect the glass and wing window going back in hopefully.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 11-05-2008, 07:54 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
looks factory correct to me. this is why my Dad always complained about GM's fit and finish.
the curved area gap is due to the drip rail being off. re-work the rial if you want ti to fit good. the gap at the bottom of the wing window area will take a bunch more work though. how does the cowl-door-A pillar-fender corner look? can you post some pics of that?
68C15 is offline   Reply With Quote
Old 11-05-2008, 07:57 AM   #8
70GMCer
70GMCer's Avatar
That looks better than a lot I've seen.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-05-2008, 01:30 PM   #9
lyrikz
PITbut
lyrikz's Avatar
Top hinge is solid, i rebuilt the bottom hinge because it was sloppy... There is no play in the door when its bolted in. The door is a 72 GM door. Kinda rusty. The door is NOT original to the truck, its a junkyard door. And if you look at the top of the door frame, it kinda bows up in the middle as if someone lifted it from there and bent the frame upward causing the back to come in some. The door openings were not braced when the rocker and cab support was cut out.
I might go that route. Doesnt seem that hard to do..
Don
Well, i have the lines in the door aligned, and the rocker aligned and the top just doesnt fit. I like your idea though.. Alot.. Thank you.
LockDoc
Your good.. Truck was wrecked on that side... Other side aligned fine.... Im painting the top black, so that helps alot on hiding door alignment issues. Dang. I have a feeling that door opening may be bent.. IM going to just undo the spot welds and adjust that door pillar...
Im going to slap in a test door to see how it fits... If its crappy, then i will adjust the door.
its even better since i tweaked on it a bit.. Still doesnt fit right in the upper right corner and the lower left ....
Old 11-05-2008, 01:44 PM   #10
mrein3
mrein3's Avatar
Didn't I read here, or was it listening to my dad who worked at the St. Paul Ford plant for 42 years, that doors were aligned at the assembly plant with a 2x4? You bent the door frame by closing it on a hunk of 2x4.
I'm glad mine aligned good enough because I'd be afraid of bending them.
Now that I'm on the subject of using 2x4s on your doors, I watched in horror one day as my dad whacked the door glass track on to the window with a hunk of 2x4. He was over and I mentioned that I had a new track, a new piece of rubber to put between the track and the glass, and couldn't figure out how to put it all together. He took the glass, rubber, and track out on to the grass in the lawn, lined up the rubber and track, and whacked the $#!+ out of the bottom of the track to get it on the window.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-05-2008, 03:39 PM   #11
c10addict
c10addict's Avatar
I cut mine at the top where the A pillar meets the roof and took 1/4 inch out... I am running 1 piece windows so I did not have to worry about the vent window fitting back in properly...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 11-05-2008, 03:55 PM   #12
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Originally Posted by mrein3 View Post
with a 2x4?
they are kinda like duct-tape
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 11-05-2008, 04:01 PM   #13
lyrikz
PITbut
lyrikz's Avatar
My plan is to remove the spot welds at the rear of the window track and move it UP 1/4 of an inch. Reweld it in and if i dont like how it looks i will do what you said and take some out of the top of the a pillar area....
Old 11-05-2008, 04:13 PM   #14
c10addict
c10addict's Avatar
Just looking at it I think that the door will hit the cab in that front corner.... Looks tight now and if you raise the back that will move forward... unless you cut it where I cut mine to allow that gap to open up so just the top move up then reweld it.. Never the less... Good luck!
Old 11-05-2008, 04:14 PM   #15
lyrikz
PITbut
lyrikz's Avatar
Can you take my picture and use MS Paint and draw where you cut, or what you think i should do, i would appreciate it.
Old 11-05-2008, 04:38 PM   #16
c10addict
c10addict's Avatar
The yellow line is where I cut mine and pulled it tighter together allowing more clearance /making the gap even.... In blue is where I think you are talking about cutting yours and I feel it would make it hit where the blue arrows are.. I feel like John Madden...... Boom!
Old 11-05-2008, 04:48 PM   #17
lyrikz
PITbut
lyrikz's Avatar
Awesome paint skills...
the back section i wont cut, im going to remove the spot welds and lift it a tad right there... Heres my idea.. Let me know what you think...
On the right red, move that up 1/4 of an inch and reweld in place. and on the left, cut at the red line, move the top window rail down, and move the side rail IN. that will make those areas line up. .Im not worried about the wing window fitting because i have one piece windows. I think that will work.. An we are only talking about | | That much if not less that i need to remove...
Old 11-05-2008, 04:59 PM   #18
c10addict
c10addict's Avatar
Looks good.. I think you will find that cutting it where I cut mine to make your adjustments in the front will be easier bodywork... I considered all aspects when I did mine... Looks like some sweet rigs in the reflection!
Old 11-05-2008, 05:00 PM   #19
lyrikz
I can't see your photo from work, but sounds like what I had to do. Yes you are thinking correctly about the welds. I had to do the same thing on my passenger door (came from different truck). Check out my build thread...starts about Post #111
http://67-72chevytrucks.com/vboard/s...=221437&page=5
Old 11-05-2008, 05:05 PM   #20
lyrikz
PITbut
lyrikz's Avatar
Ya, i stared at my pic and yours would do the same thing, but easier. ahaha.. I like your way.. those rigs are my neighbors. Old buckets....
lyrikz
I will check it out. Thank you.
Old 11-05-2008, 05:28 PM   #21
lyrikz
PITbut
lyrikz's Avatar
lyrikz
I checked out your post. Good info... Im going to have to lower my front apillar and then raise the rear... I will take an updated pic of what it looks like now and go from there.
Old 11-05-2008, 06:47 PM   #22
Now that I figured out the photos in here, yeah your door top looks like it got tweaked and I think C10addicts suggestion might be the best bet.
However before you cut, I think I might try placing a 2x4across the top of the door and whack it a few time to get that bow out, then release the loosen the welds on the rear of the door and see it you can get it to align better without the cut. If not, then do the adjustments with the cut suggested
Old 11-05-2008, 06:51 PM   #23
lyrikz
PITbut
lyrikz's Avatar
On it.. Thank you all...
More pics to come soon...
Old 11-05-2008, 06:57 PM   #24
c10addict
c10addict's Avatar
The part that sucked the worst for me is both of my doors were brand new Goodmark doors! Out of the box and under the knife!
Old 11-05-2008, 07:01 PM   #25
lyrikz
PITbut
lyrikz's Avatar
Ouch...
I know that my top rail in the middle bows up... Im going to use the 2x4 method, beat on that middle section for a bit.. Then recheck the fitting... If that doesnt help, go with the right section first.. Hopefully i dont have to cut the apillar of the door.. that would suck. ahah...
