Old 05-08-2002, 03:22 PM   #1
Edmond
Edmond's Avatar
Talking Rear Axle Websites?
Hi,
Can anybody give me URL's of websites about rear axles used in our trucks?
Thanks in advance.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400,
Edelbrock Victor Jr., Holley 750 cfm
1974 Chevy Camaro Z28 (Original)
1987 VW Golf 1.8i
1983 Yamaha XS650 Heritage Special (Wife's bike)
Capelle a/d IJssel,
The Netherlands
http://home.hetnet.nl/~epw-awes/index.html
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
The Netherlands
Edmond is offline   Reply With Quote
Old 05-08-2002, 04:33 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
go to www.google.com and search using keywords related to trucks chevy axles, carriers, etc, coloradok5.com has some info in the tech section and pics, you ownt find any info about the 3/4 ton or 1 ton axles except the danas, good luck what do you want ot know ?
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-08-2002, 04:40 PM   #3
Edmond
Edmond's Avatar
Talking
I need new wheel bearings.
3 years ago, when I bought the truck, they put in new bearings.
They are broken again, and I can't find any
bearings for it.
I don't think I have the Dana axle, the back of the housing is perfect round, so that's an GM axle?
Cya,
Edmond
1987 VW Golf 1.8i
Capelle a/d IJssel,
The Netherlands
The Netherlands
Old 05-10-2002, 03:54 AM   #4
Edmond
Edmond's Avatar
Talking
ttt
The Netherlands
Old 05-10-2002, 10:00 AM   #5
ckhd
ckhd's Avatar
Post
Edmond, that is the corporate axle. H-052 or H-072. I think there are only minor diffrences in the two.
I know that Randy's Ring & Pinion http://ring-pinion.com/home.html at least knows what they are and I know they have some parts for them.
Good luck. I'm going to change mine to a Dana 70 if I can find one that I can afford. Those 4.57s are just too much, and spending $500+ to go to 3.90s is too much too. Not to mention the limited locker availability...
Bowen
'68 K20 fleet
'69 K10 swb fleet
'72 C10 lwb step
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 05-10-2002, 11:41 AM   #6
Fast68Chevy
Post
you could always put in a 14 bolt, most all are 4.10 ratio and alot of them are bolt in(in leaf rear 67-72 trucks) except for one lower shock mount, but thats easy fix.
personally i owuld spend $0 on a eaton 3/4-1 ton (10 bolt) axle unless i really really had to...
good luck
Randy- Lincoln, IL
[This message has been edited by Fast68Chevy (edited May 10, 2002).]
Old 05-10-2002, 04:50 PM   #7
Edmond
Edmond's Avatar
Talking
That option is even more difficult. Scrapyards with only older american cars/trucks is a problem in the Netherlands, there aren't any as far as I know.
Later models maybe, but not 67-72 trucks.
Which years trucks can I use if I want to make the swap? Any eighties or nineties models?
Thanks in advance.
Cya,
Edmond
1987 VW Golf 1.8i
Capelle a/d IJssel,
The Netherlands
The Netherlands
Old 05-10-2002, 04:53 PM   #8
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
Post
one of the reasons i havent begun the restoration of my dads 71 cheyenne 4x4 3/4 ton is b/c the corporate axle is gonna cost some where around $1200 bucks to have rebuilt. Only one place in town will work on them b/c of some bearing in em they dont wanna be liable for.
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Intake 850 cfm carb Comp Cam 268/.500 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
    Put it to the floor...
-Nic
Lutz, Fl
My Team Website
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 05-10-2002, 05:03 PM   #9
Vince M
Vince M's Avatar
Post
You could try a auto parts distributor in the US such as AutoZone or the likes. They have a web site and if you put in the year truck etc..it should give you a part nummber. Then try inputing different years to see if you can get the same number. The wheel bearings I think are the same as later model axles and even the 14 bolt. I'm not positive but the hubs on my Eaton sure looked the same as the ones on my 14 bolt. I threw the Eaton away...the whole thing..parts are expensive if you get nto the gears and or ring pinion bearings. Some parts are not available at all. This is what made me give up on it. I would be kinda concerned though as to why the bearings only lasted three years. That is a very short lifespan. Maybe something else is wrong or the assembly was bad to begin with.
Orlando,FL
72 Chevy 4x4 3/4T CustomCamper w/SB 406
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 05-10-2002, 05:31 PM   #10
Edmond
Edmond's Avatar
Post
Well three years is indeed a short life span for bearings. 3 Years ago it took 4 months before they found the right bearings. (In the US)
This time I saved the boxes the bearings and oil seals came in with and gave these at my
shop mechanic. When he ordered the parts the numbers were incorrect. Strange but true.
As soon as I get the boxes back I will post these numbers, maybe one of you guys can tell me what bearings they are.
So now back to the axle swap. Which years truck can I use as a donor? Because if this axle is giving me that much trouble and parts are hard to come by than maybe that's the best option left...
Thanks in advance,
Cya,
Edmond
1987 VW Golf 1.8i
Capelle a/d IJssel,
The Netherlands
The Netherlands
Old 05-11-2002, 03:09 AM   #11
Edmond
Edmond's Avatar
Unhappy
Autozone came up with not available
Can anybody give info on the axle swap?
Cya,
Edmond
1987 VW Golf 1.8i
Capelle a/d IJssel,
The Netherlands
The Netherlands
Old 05-11-2002, 07:11 AM   #12
A.P.
Black 72 Chevy
A.P.'s Avatar
Question
Try looking at this web site for your wheel bearings. Hope it helps. http://www.americanclassic.com/ http://www.americanclassic.com/asp/dyncatv2.asp
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 05-11-2002, 11:11 AM   #13
Fast68Chevy
Post
if you have leaf rear and not a 4x4 or a longhorn or a 1 ton then a 14 bolt 3/4 ton axle iwll bolt in, if you use the same year U bolt plates, only need to worry about moving one of the upper shock mounts in the frame,
good luck
Randy- Lincoln, IL
Old 05-11-2002, 06:11 PM   #14
Edmond
Edmond's Avatar
Unhappy
I have a Longhorn....
Cya,
Edmond
1987 VW Golf 1.8i
Capelle a/d IJssel,
The Netherlands
The Netherlands
Old 05-11-2002, 06:45 PM   #15
bbs1965
Open Sundays 10 till 10
Post
Man I have a 1981 3/4 ton rearend I would sell you for $20 bucks down in Texas
parts for sale always
30 minutes south of Dallas on I35
WWW.BBSAutoSalvage.com
bbs1969@direcway.com
bbs1965 is offline   Reply With Quote
Old 05-11-2002, 06:52 PM   #16
Edmond
Edmond's Avatar
Post
LOL!!
And I should pick it up myself?
All the way from the Netherlands? I'll pass...
Thanks anyway
Cya,
Edmond
1987 VW Golf 1.8i
Capelle a/d IJssel,
The Netherlands
[This message has been edited by Edmond (edited May 11, 2002).]
The Netherlands
