Old 11-04-2008, 11:27 PM   #1
70LonghornCST
Moderator
70LonghornCST's Avatar
Sending Unit part # 6429115 ...will it work on a 1970?
I am looking at getting an NOS sending Unit part # 6429115 ...will it work on a 1970? It says it's for a 1972 Chevy truck Are they the same?
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 11-05-2008, 12:43 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Sending Unit part # 6429115 ...will it work on a 1970?
I was browsing a LMC catalog and it shows sending units and what the differences are (IE gauges or lights). I tried to look it up on LMC's web site but it's not that friendly, in fact it's impossible to locate sending units period.
sorry,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-05-2008, 04:08 AM   #3
JimKshortstep4x4
Does the sending unit you are looking at have a single outlet or does it have two outlets?
The difference is going to be in the hookups of the gas line. The 70 will have a single outlet, either a 5/16" female fitting or a 3/8" female fitting.
The 72's that I have seen have two lines on the sending unit and are connected using fuel hose. Chances are that it will not be a direct swap out but could be made to work as the ohm output will be the same.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-05-2008, 04:39 AM   #4
70LonghornCST
Moderator
Thanks, Jim.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
