Old 11-05-2008, 12:53 PM   #1
Hair
POR15 life after can is open
After I open a can of POR 15, use some, and close it back, approximately how long will it stay good? I've heard that it goes bad and hardens pretty quickly once opened. How long is "pretty quickly"? Hours, weeks, months?
Hair is offline   Reply With Quote
Old 11-05-2008, 01:07 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: POR15 life after can is open
Only pour what you need into a separate container for the job. If you reuse the original can to store in, make sure you put a piece of Saran wrap between the lid and the top of the can to prevent it from bonding together (you will never be able to pry it apart) Make sure there is NONE on the lip of the can when you put the lid back on. A better way to store it is to pour it into a jar to seal it up real well, keeping care not to get any on the rim of the jar or the lid seal. Once exposed to the air, it starts to cure relatively quickly. Pour some in a conatainer, and recover/reseal the rest immediately. I have heard varying results as far as shelf life goes....it all depends on how well you seal it up. I have had a can last for months, and others just for weeks.
leddzepp is offline   Reply With Quote
Old 11-05-2008, 02:03 PM   #3
OldCreek
OldCreek's Avatar
I've had a can that I reopened multiple times and it lasted for months. I did, however, store it in the refrigerator.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-05-2008, 02:11 PM   #4
STP67-72
STP67-72's Avatar
I was told years ago to put a sheetmetal screw in top and one on side of can so it will vent. Put it at the top of can. I have had a can for about 8-10 years. Have used it several times. Use a hex head, so you can get them out. Never take the top off. Hope this helps.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 11-05-2008, 02:33 PM   #5
Prostreet 72
Prostreet 72
Prostreet 72's Avatar
They also tell you after you put the plastic wrap between the lid and the can, you should store it upside down. This allows the material to skin over on the bottom of the can instead of the top. It works.
Prostreet 72 is offline   Reply With Quote
Old 11-05-2008, 02:34 PM   #6
Hair
Dude!! Now that is an awesome idea!
What do you do, just shake it up before you unscrew and poor? I read on here somewhere that you should stir and not shake it. Does that matter?... or does it need to be stirred or shaken at all?
Old 11-05-2008, 02:54 PM   #7
cdowns
cdowns's Avatar
i open it stir it real good(never shake the can!!!) i then drill 2holes in the lid 180apart and use sheetmetal screws to sealealup the can and i tahe the screws out and pour the por15 into my paint container// never work directly out of the por15container//after a few uses the sheetmetal screws get bonded to the can and i need to drill a new set of holes///done like that i've had a can last me 6-8months
SHAKING THE CAN gets all sorts of micro air bubbles and a very poor por finish
Old 11-05-2008, 03:27 PM   #8
Ackattack
Ackattack's Avatar
My boss sells POR15 on the side, and he told me the same thing. Seems to be working so far
Ackattack is offline   Reply With Quote
Old 11-05-2008, 06:26 PM   #9
chevy29267truck
you can also used ospho too
chevy29267truck is offline   Reply With Quote
Old 11-05-2008, 09:16 PM   #10
Huck
Huck's Avatar
don't use a power drill and bit to get through the skimmed surface---it's under pressure as it drys. NOW ASK ME HOW I KNOW THIS!!!!!
Huck is offline   Reply With Quote
Old 11-06-2008, 09:46 AM   #11
gcburdic
Restoration Virgin!
gcburdic's Avatar
Okay, I'll bite....how do you know this???
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-06-2008, 10:41 AM   #12
jorgensensc
jorgensensc's Avatar
You didn't get it on your Hootus did you?
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
