A hair-brained idea?
So, this may sound idiotic to some but.....
I was wondering if one could remove the torsion bars and just stuff some springs between the control arms (or something). I ask because I have seen people post regarding airbag suspension swaps using this location for the bags, I was wondering if I could do the same thing and just use coil springs? Trying to weigh out all my options... I don't have the $$$ to do a full front end swap from a later model (actual front end, rebuild, master/booster for disks= big $$) Thanks Matt
1962 Chevy Fleetside
283/TH350 |
Re: A hair-brained idea?
when i was pulling my torsion bars off last week I asked myself that same question. unfortunately, i don't know the answer but it looks like it could be done. I guess anything is possible with a blowtorch and a bit of creativity.
![]() Join Date: Oct 2006
you would need diffrent a arms.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Resistance is Futile
What about adding some coil-overs? Fab up some mounts and you cuold have a nice streetrod front suspension. I dont know about low-buck however. I see coil-overs on the Phx area Craigslist occasionly.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
One day...
Do they even have the pocket under the crossmember for a spring? I dont remember on mine its been a few years.. i got a whole crossmember for $125 wheel to wheel
My Frankenstein has leaf springs... So I can't make a good comment. I think my frame is an early 60's GMC something...
Scotts62: I think it would work, you can bag 'em so there is something to push against. I just dont own one so Im not familiar.
One day...
Ya its been 4-5 years since i did mine and wasnt sure if the ones with tortion bars had a spot for spring to sit, im thinkin no thats why i changed my whole X member on mine... but who knows i could be wrong id have to see one to remember
You can find the 73'-87' style trucks for next to nothing or even free. I know I have hauled several home for free. This would be a much better solution.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
I have seen other makes of trucks with torsion bars that are converted to coilovers. Seemed to work quite well. Depends on your fab. skills, but anything is possible. I will search for the pics so you can see how they were crammed in there.
Thanks for the ideas.... a few thoughts:
It sounds like the complete front end swap could be relatively cheap then, huh? I was thinking I would need to dive deep into the wallet to get all the stuff for converting to disk breaks and make all the steering line up..... or is it really just as easy as unbolting the old front, bolt up the new one, hook up the old lines and drive? I tend to over think things, which is why I was originally exploring this idea in the first place.... -Matt
283/TH350 |
#13 |
Sorry guys, maybe I wasn't clear. Here is my goal:
Get rid of the Torsion bar front end the cheapest way possible. The idea I started off this post with (cram coil springs between the a-arms)may not work due to the geometry of the vehicle (the a arm issue mentioned above)...though so serious fab work might make it happen, probably not worth the time (plus I am so-so on the true custom fab work) That being the case I will start doing homework on the 77-89 (dont remeber the correct years off hand) front crossmember swap and see how we're looking. If anyone has some words of wisdom feel free to send em my way (PM or add on here) Thanks as always! -Matt
283/TH350 |
#14 |
i have a 60 frame and did the cross from tortion bar front end to a 80 3/4 ton front end and it is as easy as taking old bolts out and redrilling some new holes and installing the hole front x member.
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
#15 |
and one more i aslo used the motor mounts from the 80 doner truck and cut 1 coil out of front springs and used the front sway bar front the 80
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed Last edited by mnky30; 11-10-2008 at 11:09 PM. |
#16 |
Junk Junkie
That's bad ass, that's the way to do it.
Mike 71 Chevrolet C-10 Short Bed Stepside 81 GMC 1500 Sierra Classic Long Bed |
#17 |
Well shoot.... those pics speak for themselves! That looks pretty simple. One question: This could be done with the engine in and the body on, right? That 1st pic I shows the bolt locations... I think I could get to them on the frame from the engine bay (unless I am missing something), but it looks like the engine rests on the cross memeber. I need to go get uner the truck tomorow and investigate!
How did all the accesories hook back in, easily? I have PS and drum breaks (single master), what did you start with? Thanks for those pics! Matt
283/TH350 |
#18 |
the engine sits on the cross member, plus it is easier to get to everything with the engine out.
you could probably raise the engine with a hoist and get it done also, if you don't want to pull it all thee way out do you currently have power brakes? you have converted power steering? or original power assist?
![]() ![]() Last edited by joe231; 11-11-2008 at 09:49 AM. |
#19 |
I don't have power breaks, I have drums (which are practically flinstones breaks)
I think I have original power assist. I have a resivour/pulley connceted to the engine, with hoses that run to the box
283/TH350 |
#20 |
oh, and my master (no booster) looks like a matchbox
283/TH350 |
#21 |
i think you could do it with the cab on no problem but the engine would have to be lifted or removed and all the accessories brake lines i welded a tab on the frame to mount them and then just got some new brake line and rerouted it to a porportion valve on the frame. the steering i used the original idler arm from the 60 and the rest hooked up to my power steering box i mounted from the 80 frame.
#22 |
Lifting the engine up will work but I'm finding that it gets in the way sometimes. At one point, I had a ratchet look more like a snake than a tool
#23 |
Ok... so if I am doing my math right....
pulling engine + pulling front crossmember = less overall work and aggrivation then slightly lifting the engine and trying to work around it.
283/TH350 |
#24 |
yep
#25 |
If you are to the point of lifting the engine you are 95% to having it out. It just makes seance to remove the engine to perform the work. Also this gives you the opportunity to detail you engine or address any other issues. Your best bet it to locate a donor truck 73'-87 1/2 ton or up to 91' 3/4. They all used the same X member but the 3/4 used the big spindle and brakes. You can use everything off of the donor including the master cylinder whether it be power or manual. These trucks are fairly easy to come up with for little or nothing.
